Question about Labtec 9674170403 Keyboard
Mouse shuts off
HI,I've installed new labtec U-flat wireless(usb) Keyboard and mouse.Evrything works,but the mouse goes off when I use scroll whell for a few times.The red lit under goes out.To turn mouse on again, I have to take out the batteries from mouse and put'm back on.If I don't touch scroll whell,it works fine.I believe this is a hardware problem,but if you have any ideas...thank you for any help.
  • 3 Answers
Hi there first of try new batteries may sound silly but it is the case sometimes secondly try going to your device manager and then select your mouse hardware go to properties and then update the drivers if you cant access the internet try and borrow a friends computer to download the drivers and then load them on your computer thanks
Posted on Feb 13, 2008
Hi, i have just purchased a labtec wireless keyboard and mouse and am experiencing some problems. the keyboard only becomes active when windows is launched, so i can't make any changes to the bios. can you...
Hello, two possible solutions spring to mind.
1) Get yourself a standard wired keyboard to plug directly into the ps2 purple socket (next to the green one, which is the mouse connector) just keep it for those 'special needs moments'.
2) If you are plugging your wireless keyboard receiver directly into a usb socket, then you should have an adaptor supplied with your keyboard receiver that enables you to plug the usb end of the keyboard cable into the ps2 keyboard socket of the computer (the purple one) . That way your wireless keyboard will be able to work at bios level.
Hope you find these suggestions useful!
nicam49
Dec 30, 2010 | Labtec Wireless Desktop (967263-0403)...
Does the labtec wireless mouse turn itself off when not in use
You should always safely shut down and turn off your computer before plugging or unplugging the mouse from the PS/2 mouse port. If you do not safely turn off your computer, you may damage the mouse port, the mouse, or both.
Your Labtec mouse should detect and function by simply connecting it to the computer´s PS/2 mouse port or USB port. If you have 3 Button Labtec Mouse (M/N: M-CAC64), your mouse will work in the PS/2 and serial port with the supplied adaptor. If you are using the 3 Button Labtec mouse, we recommend using the PS/2 port. To determine the model number of your device, turn it upside down and look at the label. Model numbers are indicated by "M/N:". This will help you determine what system ports your Labtec mouse can be connected to.
Thank you
Mar 14, 2010 | Labtec Wireless Desktop Keyboard/Mouse...
Same problem winXP cannot find driver for labtec
There are drivers available here
http://www.opendrivers.com/freedownload/248954/labtec-media-wireless-desktop-800-v6.0-windows-vista-xp-2000-download.html
Aug 04, 2009 | Labtec Wireless Desktop Keyboard/Mouse...
Activation of keyboard
Did you receive a install disk for the keyboard and mouse. typically you need to run the install disk and then plug in the usb hub for the keyboard and mouse to be recognized by the computer. If tha does not work, restart the machinew/the usb hub and keyboard and mouse ready. Are there good batteriesin the keyboard, mouse and usb hub?
May 03, 2009 | Acer Computers & Internet
NEED INSTRUCTIONS FOR Labtec Media Wireless Desktop keyboard , mo
This automatically shut down, but it is totally not efficient (the mouse need 10 minutes to shut down, and the keyboard can be shut down, perhaps with a keyboard shortcut (I do not know witch). My keyboard is off, and I cannot wake it up... Do you know witch tastes need to be pressed, I tried quite all, especially the connect button...
Dec 07, 2008 | Computers & Internet
Labtec Wireless Desktop Keyboard and mouse driver
Also check to see if you have enough memory installed as this has caused problems for others. Bud
Oct 22, 2008 | Labtec Wireless Desktop Keyboard/Mouse...
Labtec ultra flat wireless desktop usb mouse & keyboard problems
im having simular problems but manage ome times by tapping caps lock,scrol lock and num lock from the momment you pc starts till the caps lock majes a noise, then i know its working, if mouse starts mocing slow and not clicking it is your batteries, got me mad this has and dunno how i aint smashed it lol
Jun 13, 2008 | Labtec 9674170403 Keyboard
Labtec Wireless desktop 1200 not working- win xp sp2
Seen to be a problem with power manager.
On Linux the solution what
echo -1 >/sys/module/usbcore/parameters/autosuspend
I find it here:
http://www.linuxquestions.org/questions/linux-hardware-18/usb-error-usb-2-4-device-descriptor-read64-error-71-643022/
Apr 26, 2008 | Labtec Wireless Desktop Keyboard/Mouse...
Wireless mouse and keyboard
Push the connect button on the wireless base, then push the connect button on the keyboard or mouse, that is supposed to reconnect the device. Make sure the wireless base is close enough to the keyboard.mouse, and nothing metal is blocking the path between the keyboard/mouse and the base.
Jan 25, 2008 | Labtec Wireless Desktop Keyboard/Mouse...
Labtec wireless desktop.
Could be radio interference from somewhere. I tracked my similar mouse problem down to emissions from the ethernet adapter that connects over the house mains wiring. Try the using the mouse close to the receiver, if it works ok interference is likely.
Jan 24, 2008 | Labtec Wireless Desktop Keyboard/Mouse...
Labtec 9674170403 Keyboard Logo
371 people viewed this question
Top Labtec Computers & Internet Experts
micky dee
Are you a Labtec Computer and Internet Expert? Answer questions, earn points and help others
