Question about Maytag Performa PAV2200
Dryer turns on doesnt dry - Maytag Performa PAV2200
    Scholar:
  • 196 Answers
Suspect heating element or thermal fuse. The heating element and fuse can be checked with an ohm meter. The reading should be 0-2 ohms on both devices. If heating element reads infinity (nothing) replace heating element and fuse. If the fuse reads infinity then replace the fuse.
Posted on Jan 08, 2008
It heats up but doesnt stop after the clothes are dry
IT is the timer. If electronic needs to replace the board. If dial type, needs the timer
Sep 15, 2014 | Dryers
My whirlpool dryer lgr6620pqo doesnt dry clothes enough already replaced cycling thermostsat seemed to work now still not drying enough
Clean/Replace your dryer vent hose; also, make sure it is as taunt and short as possible. Any extra loops or turns prevents proper air flow (moisture) from leaving the dryer and being vented outside.
Also, check your outside dryer vent; sometimes critters make a home in the warm vent.
Hope this helps...
Jan 07, 2012 | Whirlpool Dryers
My maytag atlantis dryer heats up but on any cycle the dryer doesnt run long enough to dry the clothes i have to turn it on two or more times to dry clothes
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Mar 21, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
I have a Kenmore 70 top load dryer that is not heating. And the timer doesnt turn off anymore either. Both items seem to have malfunction at the same time. Help?
This is typical. If the heating element is no longer working, the unit doesnt know to turn off due to the clothes still being wet. However, the timer has absolutely nothing to do with the heating of the unit. If the timer doesnt turn off the unit even when the time is short (example: 10 minute timed dry), the timer has a different issue. If you have merely set the dryer to dry the clothes (not a "timed cycle" to dry) then the dryer will continue to run as I have stated before. The dryer will run until the clothes are dry. Now, its time to address the heating part. Your dryer heating element has gone bad. It can be replaced if you are somewhat handy. You can pick one up from your local appliance store and it has simple instructions. Please make sure that you disconnect the unit from its power source prior to attempting any repairs. Safety First. You can also call someone to replace it for you and it shouldnt be too costly. Good luck on either option.
Feb 08, 2011 | Kenmore Dryers
Hello my dryer doesnt work properly it runs
The valve resistance is 1995 ohms and the ignitor is 185.
Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When the dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
LG dryer manual
Dec 13, 2010 | LG D2526 Gas Dryer
Maytag gas dryer wont turn off when done drying in auto dry regular fabrics. does turn off in air fluff and auto dry perm. press. model # d3382
auto dry relies on a moisture sensor to say when its done. so your clothes arent dry enough according to sensor. perm. press. doesnt dry the clothes as much
Aug 01, 2009 | Dryers
Dryer does not heat
check the heater and fuses.
Jun 28, 2009 | Roper RGX4634KQ Gas Dryer
My dryer doesnt work
check the door swich to be sure made up properly
Dec 29, 2008 | Kenmore 659 Electric Dryer
Dryer doesnt turn on
take the top of your dry off and look by the buzzes to see there fuse there it could need new one
Apr 18, 2008 | GE DSKP233EWWH Electric Portable Dryer
Washing Machines Logo
173 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
