Question about KitchenAid 24 in. KUDP01IL - Multiple Color Built-In Dishwasher
KUDP 02FRSS2 dish washer
Contractor turned a breaker on and off, pretty sure it was this one and the washer no longer powers up. Everything else around it still works. Is there a fuse box or reset button that i can access to reset the unit?
treece1986@aol.com
  • 90 Answers
Fuse on control board
Posted on Jan 07, 2008
Power is getting to my Bosch Exxcel dishwasher but it won't turn on. (None of the lights come on)
Start with the basics. Double check your power and circuit breaker. Next there is a float in the bottom of the dish washer located inside make sure this is free and clear.
Jan 06, 2017 | Bosch Dishwashers
How to repair my kenmore dish washer not powering on but shocked me before it shut down for good ?
it sounds to me as though you may have a bare wire giving a direct short to the system.therefore by having a hot wire grounding out on the dishwasher body, it is running that current to the dishwasher body where if you touch the dishwasher you will recieve a shock.this also doesnt allow the electricity to go to where it is needed to power your appliance.
May 20, 2014 | Kenmore Dishwashers
Dishwasher not working after circuit breaker turned off
Circuit breaker tripped because of fault in dishwasher, which is why it no longer works. Sorry but I can not tell you what dish washer fault is.
Sep 13, 2017 | Bosch Dishwashers
Dishwasher trips breaker. Breaker only resets of door is opened
wires rubbing inside dish washer , surprising its not blowing fuse in dish washer plug .
Mar 25, 2013 | Dishwashers
CLEAN LIGHT BLINKS 7 TIMES ON KITCHEAID KUDP DISH WASHER
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Aug 08, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
I havn't used my dish washer in over a year and it wont turn on. Why?
check to make sure you have power to the outlet, it should be located under the sink,, if you do not have power at the outlet then check the breaker in the breaker box.
c...
Jan 02, 2011 | GE Nautilus 24" Built-in Dishwasher
My dishe washer wont turn on
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced
Now, if you have confirmed that the unit is receiving power from the outlet, and the unit is still not responding, this will lead to a failed control board, or timer module. replace either the timer, or control board, in this case.
Nov 05, 2009 | Dishwashers
No power comes on and I checked the fuse/breaker
typically no reset buttons on dish washers? find the breaker that it is on turn it off with good force to make sure that if it were tripped you will be resetting it! then flip it back on
May 31, 2009 | KitchenAid KUDK01TK - Multiple Color...
Dish water won't start
hi,
you shouldn't have to pull the washer out, the fuse that may be the problem should be located in the door with the control board. there should be some screws around the door to remove it. however, the fuse may need to be special ordered. also make sure the power is off to the unit before you work on it.
Mar 30, 2008 | Bosch SHU9915UC Dishwasher
KitchenAid 24 in. KUDP01IL - Multiple Color Built-In Dishwasher Logo
134 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
