Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Problem for Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with...
Whirpool side-by-side fridge has so much water in
By penniey on Nov 09, 2009
Whirpool side-by-side fridge has so much water in bottom drain pan it is overflowing onto floor-any suggestions as to where the water is coming from?
Best Solution
posted on Nov 10, 2009
Very Helpful)
aasc
Rank: Guru  Whirlpool Refrigerators  Expert
Rating: 93%, 571 votes
If your filter is down on the refrig kick plate , then your filter is problably the cause . Replace the filter . I have found 3 lately , that the filter seals or the actual filter was cracked , letting water drip into the drain pan , causing it to over flow .
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Nov 09, 2009
Not Rated)
fix it AL
Rank: Apprentice  Refrigerators  Expert
Rating: 0%, 0 votes
one of two things is wrong 1 your drain defrost tube is blocked with sluge or whatever use comp.air or a flex rod to open it up. (2) your defroust timer could be stuck and is not going into defrost mode look on the bottom behind the grill cover or inside were the tenp. knob is look for a small knob you'll have to use needle nose pliers to turn it turn it clock wise untill the refg. stops it should start up in about 30 min.if it dosent replace the timer note you may have to defrost the coil in the freezer side take off cover and use a hair dryer DONT use a knife to chop out the ICE let it melt ps make sure the box is level.OH pour a little bleach down the drain hose to kill the sluge germs good luck
Was this helpful?
Yes
No
Popular Solutions for Whirlpool 25.6 cu. ft.
Questions and Unsolved Problems for Whirlpool 25.6 cu. ft.
Do you recommend Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System?
Answer
Answer
Whirlpool refrigerator door dispenser will not deliver cubed ice - only crushed. Depressing button... (More)
Answer
ed25lf whirlpool side by side freezer working freg. side not cooling like it should lscrvnts
Answer
Whirlpool Roper frigde RS22QXKQ04 still runs everything in freezer has defosted not sure about the... (More)
Answer
i have a whirlpool side by side fridge which has gone rusty around the water dispenser, under the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerators Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
