Question about Garmin Nuvi 660 GPS Receiver
Low Battery Just got the Garmin nuvi 200W series for Christmas. I used it for a total of approx. an hour when I started getting a low battery signal. Now when I try to turn it on it shows the name Garmin, searching for maps and then shuts off.
  • Anonymous Jan 08, 2008
    Found the problem.
    The fuse for my cigarette lighter was blown. I put a new fuse in and all is working fine.
    Thanks for your help.
    DB
  • 174 Answers
Recharge the battery or plug it into your car cigarette lighter and turn the unit on.
Posted on Jan 07, 2008
6ya staff
SOURCE:
My Garmin nuvi 200W has had a battery recall and replaced by Garmin. It powers up OK and locates OK but hangs after approx 0.5-1 hours. I cannotr even turn it off without pressing reset. I have updated the...
Send it back to Garmin. The fault may be coincidental, but unless you fancy buying a replacement model it's worth seeing what Garmin have to say. It should only have been a straightforward battery swap, but if the technician forgot to wear an earthing strap it's entirely possible that a component suffered static discharge damage.
I've been holding back from sending my nuvi 770 in as the battery seems fine and I've often had problems with shoddy recall work on digital cameras and similar devices in the past.
Sep 22, 2010 | Garmin nuvi 200W GPS Receiver
Tip
Nuvi 200W Webupdate
Garmin Nuvi 200W Webupdate
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Does your Garmin Nuvi 200 or 200W GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
____________________________
Download your Garmin Nuvi 200 Series manuals here.
Download your Garmin Nuvi 205 Series manuals here.
Garmin Nuvi Hard Reset Here.
Garmin Nuvi 200W Favorites Backup here
on Apr 17, 2010 | Garmin nuvi 200W GPS Receiver
Shuts down when driving, looses power, and goes to battery
If your Nuvi's battery is low, and the plug becomes loose, then that may be your problem. If your Nuvi is acting up due to a firmware / system software glitch (common common common), then I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites (if your computer will still recognize it or if you have a memory chip you can pop into a card reader).
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Apr 11, 2010 | Garmin nuvi 200W GPS Receiver
There is no signal in the sat
Acquisition of satellite speed has been addressed in new firmware / system software updates for the Garmin Nuvi 200W .
  1. Back up your Favorites.
I hope that helps.
___________________
Feb 22, 2010 | Garmin nuvi 200W GPS Receiver
HOW DO I INSTALL A BATTERY IN MY GARMIN NUVI 660
Replacing the nuvi 660's battery is actually not all that hard as this video demonstrates:
utube.png You-Tube video "S2KEu_if7wA" placeholder (do not delete) utube.png
The company that produced the video sells a kit which includes the battery and tools necessary to do this yourself if you'd like. See: http://www.newpower99.com/ProductDetails.asp?ProductCode=GARMIN+NUVI+660&Show=ExtInfo I swapped the battery of a friend's dying GPS using the aforementioned kit and all went well. His nuvi 680 is back up and running smoothly.
Feb 18, 2010 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
Garmin nuvi gps navigator
Your Nuvi has suffered the firmware or system software equivalent of a stroke.
I hope that helps.
___________________
Feb 04, 2010 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 200w while charging the battery it started to flash and went dead. It will not respond.
I hope that helps.
___________________
Sep 04, 2009 | Garmin nuvi 200W GPS Receiver
Loosing satellite signal
Acquisition of satellites has been addressed in new firmware / system software updates for the Garmin Nuvi 200W .
I hope that helps.
___________________
Aug 08, 2009 | Garmin nuvi 200W GPS Receiver
My garmin nuvi has trouble locating satellites and losing signals. What happened? It used to be much more reliable.
I hope that helps.
___________________
Jul 18, 2009 | Garmin nuvi 200W GPS Receiver
How do i change the battery on a garmin 200w
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Mar 26, 2009 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
210 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Sheldon Dedek
Janelle Schoonover
Janelle Schoonover
Are you a Garmin GPS Expert? Answer questions, earn points and help others
