Question about KitchenAid KSRA25ILSS Side by Side Refrigerator
Kssp42qhwoo(7 yrs old)
Refrigerator side heavy condensation and water leaking. already changed the door gasket but still did not resolve the problem
  • 90 Answers
Make sure light is turning off when door is shut
Posted on Jan 07, 2008
Ge monogram has water droplets in refrigerator side just along top right corner edge where top door gasket closes against refridgerator. Refridgerator seems to be holding temperature. Condenser is above...
The gasket may have worn some causing an air leak,.and you
are seeing water condensation from the leak. Try adjusting
the door hinge. Close the door on a piece of paper and see if
you can pull the paper out. Adjust the hinge until the paper is
tight.You may have to adjust both hinges to align it properly.
Feb 08, 2018 | GE Monogram Side by Side Refrigerator
Water leaking onto floor lower left side
Move the refrigerator out from the wall and look for the location of the leak.
Step 2
Check the side panels and the seals around the door for beads of "sweat." This could indicate a condensation problem.
Step 3
Check the floor. A puddle there could indicate a missing or cracked drip pan, or a leak in the water line that feeds your ice maker.
Step 4
Check for water seeping from the front of the freezer or the refrigerator. This could indicate your defrost drain is plugged or your ice maker is leaking.
Fixing a condensation problem
Step 1
Check that the doors shut correctly. Hold each door about halfway open, then let go. If the doors don't shut completely, adjust the screw legs on the front of the refrigerator so the unit tilts back a bit. With adjustable pliers, turn each leg one revolution clockwise. Recheck the doors and, if necessary, repeat the process until they shut securely.
Step 2
Inspect the door gaskets. Look for debris that may keep the doors from shutting. Also check for cracks or gaps in the gaskets that could allow the cold air to seep out. If you find debris, clean the gaskets with warm, soapy water. If you find cracks or gaps, you'll need to replace the gaskets (see How to Fix a Refrigerator That Cools Poorly).
Step 3
If your refrigerator is equipped with a door-frame heater that evaporates condensation, make sure the heater is turned on. The switch should be located with your other refrigerator controls
Hope this helpout....
Aug 15, 2010 | GE Refrigerators
Water dripping inside refigerator
Step 2
Step 3
Step 4
Step 1
Step 2
Step 3
Hope this helpout.......
Aug 15, 2010 | Kenmore 53642 / 53644 Side by Side...
I have an Amana side by side refrigerator model SXD225SW and the other day water began leaking from underneath the refrigerator. As the couple of days have worn on, it seems as though the amount of water...
Step 2
Step 3
Step 4
Step 1
Step 2
Step 3
Aug 15, 2010 | Amana SXD524VW Side by Side Refrigerator
Leak in the drainage pan under frige
1. Check that the doors shut correctly. Hold each door about halfway open, then let go. If the doors don't shut completely, adjust the screw legs on the front of the refrigerator so the unit tilts back a bit. With adjustable pliers, turn each leg one revolution clockwise. Recheck the doors and, if necessary, repeat the process until they shut securely.
2. Step 2 Inspect the door gaskets. Look for debris that may keep the doors from shutting. Also check for cracks or gaps in the gaskets that could allow the cold air to seep out. If you find debris, clean the gaskets with warm, soapy water. If you find cracks or gaps, you'll need to replace the gaskets
3. Step 3 If your refrigerator is equipped with a door-frame heater that evaporates condensation, make sure the heater is turned on. The switch should be located with your other refrigerator controls.
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
Check out this link, its a video shows you how to fix a leaking fridge.
Apr 21, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I've got a GE side by side refrigerator that's approx.7 years old. This past weekend, I resolved the problem of not getting water out of the cold water dispenser. After replacing the two-way water solenoid...
Check around the door gasket to see if gasket pulls off or is it held on by screws if there are screws you can separate the door and insulate the tube if no screws than replacing the door is the only repair.
Jan 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I am finding water on the top shelve of the refrigerator as well as under the vegetable bins. Is there something I can do or is it time for a new refrigerator? Not sure that is the model number, had this...
The water is probably condensation. If you are in a humid area and the refrigerator is opened and closed often the humidity in the air will condense on the cool surfaces of the shelves and sides and will run down to the bottom of the refrigerator. If it is very old the door gasket may be deteriorated and leaking air into the refrigerator. Check it by closing the door with a dollar bill sticking out. If you can pull the bill out easily when the door is closed the gasket should be replaced.
Oct 29, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Condensation on refrigerator front btwn top freezer and refrigerator doors
I have the same problem with my frig in the basement. I get condensation and resulting mold on the top outer surface and related areas. This is from the surface being cold, with resulting outside moist air condensing on the cold surface. Best solution - spray/wipe the surface with a bleach and water solution, let it soak a few minutes, then wipe off with a rag. Add a drop of dishwasher soap to a mixture of roughly 4 parts water to one part bleach. Repeat if necessary. Do this as often as the problem seems to creep up again. Good luck!
Handyman in NJ
Oct 01, 2008 | Frigidaire FRT18B4A Top Freezer...
Kitchen aid -Superba 42,
Make sure the fan motor is running in the freezer.
Sep 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Check and make sure you defrost drain in the freezer isn't frozen. The water may be coming from the bottom of the freezer inside. When the heater comes on to defrost the evaporator, the water drips in to a small hole in the back bottom of the freezer inside. If the drain freezes, the water runs out into the freezer on the bottom and eventually onto the floor in front of the freezer door. It will eventually create a gap and let moisture into the freezer and may show up in the refrigerator section as condensation. Remove the ice build up including the alluminum drain pan area where the drain is located. Pour hot water into the drain to defrost it. You may have to remove the back of the freezer wall on the bottom to get better access. If the water goes down the drain, its clear. If you need a part for your refrigerator, please email me on ebay under user name themackshack. Good luck! , Mack
Jan 06, 2008 | KitchenAid KSSP42QKS Side by Side...
KitchenAid KSRA25ILSS Side by Side Refrigerator Logo
65 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
