On many Acer 6920's BlueTooth is an option . You have the switch, but you may not have the card . You can buy a card, and cable for $25, but the complete bottom case must opened to install the system . It only requires plugging on the cable to the main board, and the other end to the bluetooth card, and mounting the card with 2 small screws in it's provided location . The most dificult part is not loosing any screws . You may want to install an Intel Turbo Memory Card at the same time . There is an empty slot for that, too . Just 2 more screws . Hope this helps, J
The Acer Aspire 6920 is available in four different versions, so chances are that your laptop does not have the bluetooth feature even if there is a button to turn it on.
I recommend that you find your manual and check to make sure that is has the a bluetooth feature.
How do i reset the touch pad? it is locked at max volume and will not work when touched. None of the...
(More)
How do i reset the touch pad? it is locked at max volume and will not work when touched. None of the touch pad is working at the moment
My acer 6920 started making a noise when it is not plugged into the wall or not on highest...
(More)
My acer 6920 started making a noise when it is not plugged into the wall or not on highest brightness. I don't know what is wrong, but when it is not on full brightness it makes a really annoying buzzing sound. please help!
I have a acer 6920 gemstone blue, and i have a hdmi port on the left hand side of the laptop. it has...
(More)
I have a acer 6920 gemstone blue, and i have a hdmi port on the left hand side of the laptop. it has a plastic cover. i am wondering if it is an actual hdmi port that i can take the cover off or if it is just for looks... i have tried everything i could think of to take the cover off and it doesn't seem to move at all.
i have a aspire6920 I loaded a utilitie4s disc that made my computer run slower I uninstalled it and...
(More)
i have a aspire6920 I loaded a utilitie4s disc that made my computer run slower I uninstalled it and shut my computer down When i turned it back on it says no operating system and ask for a HDD password its not the same password i had so i cant get to theHDD utitlitiues help
