Question about IBM ThinkPad 600E 2645 Notebook
Error codes for ibm thinkpad 600E
I keep getting an error code, 161 & 163. after i set the date and time a on and off screen pops up and i cant remove
    Sergeant:
    Champion:
  • 243 Answers
Your bios battery needs replacing
http://www.bioscentral.com/misc/ibmdiag.htm
Hope that fixes it for you? :)
Posted on Jan 06, 2008
Error message 00173,00163 will not boot corrctly
These errors are system options not set, and time/date not set (if I recall correctly off the top of my head)
Basically, you need to replace the CMOS battery.
I would order one online from a place like EVERCORP.com ( a link for YOUR battery is here... http://www.evercorp.com/catalog/batteries/Laptop/Laptop+CMOS/IBM/ThinkPad+600%2C+600D%2C+600E%2C+600X/CR2025-WR/ )
It will cost a lot of money though...almost $10 ! And there will be shipping on top of that, and the battery weighs almost a whole ounce!
If you can maybe second mortgage your house so that you can afford these hefty costs, the installation is almost as hard as the price is high.
Fear not though, installation instructions should come with the battery (which hides in the RAM compartment as I recall).
Once the battery is replaced, set the system options and the time/date, and you should never see that error again!
Jun 27, 2011 | IBM ThinkPad 600E 2645 Notebook
Got an IBM thinkpad with error 00163?? Any help guy's?
This error code means the BIOS Date and Time needs setting.
This is caused by a flat BIOS battery.
Replace the BIOS battery, it will be a battery with a lead and connector and the battery will have yellow plastic surrounding the battery.
Jan 30, 2010 | IBM ThinkPad 600E 2645 Notebook
Error 163 173 ibm 600e laptop when turned on these errors occur
this error is the battery by the sound of things, you need to replace the cmos battery , then enter the configuation utlity and set date and time, hope this helps
Nov 29, 2009 | IBM ThinkPad 600E 2645 Notebook
Error 00161 00163 unit comes on and shows this screen any imput would be great thanks
According to the error codes, you have a dead backup battery and the time is not set.
Start with the machine OFF. HOLD DOWN and CONTINUE TO HOLD THE "F1" key.
WHILE STILL HOLDING "F1", turn the power on, and CONTINUE TO HOLD "F1" This will get you into the bios "setup." You should check the date
The "hardware maintenance manual" shows you how to maintain this machine, and it explains the meaning of the error codes.
This will get you started on looking for the manual:
http://www-307.ibm.com/pc/support/site.wss/multiplefiledownload.do?validate=true
Nov 21, 2009 | IBM ThinkPad 600E 2645 Notebook
Hello my ibm thinkpad 600E will not come up. it says error 00161 and 00163. what do i need to do?
Do you know how to get into bios/setup?
Start with the machine OFF. HOLD DOWN and CONTINUE TO HOLD THE "F1" key. WHILE STILL HOLDING "F1", turn the power on, and CONTINUE TO HOLD "F1" This will get you into the bios "setup." You should check the date, bootup order, etc, and reset. I would check the "wire" you think you reconnected---you may just not have actually reconnected it.
backup battery = CMOS battery
According to the error codes, you have a dead backup battery and the time is not set. Error: 161
(Dead battery.) 1. Go to Checking the Backup Battery
2. Backup battery.
3. System board.
Error: 163
(Time and date were not set.) 1. Set time and date.
2. System board.
Jul 14, 2009 | IBM Computers & Internet
Starting ibm 600e
Hi there.
Errors 161, 192, 163.
All three of these errors are connected to the back up battery.
To resolve this problem:
1. open memory flap on base of laptop (small philips screwdriver required)
2. find the small connector with 1 black & 1 red wire coming from it.
3. disconnect above connector and gently pull the Red&black wires. The backup battery should just pull out from under the casing.
4. get replacement battery. Either
a. call IBM spares (07900 247 490 in UK) and ask for FRU:
02K6502. UK price is about £8 + £15 delivery + VAT.
b. if comfortable with soldering iron: Carefully open the packaging on the backup battery using a sharp knife.
Remove the solder tags from the battery (these are spot welded so need to be cut/broken off). Buy a new CR2025 battery from any computer shop, jeweler, or camera shop.
Using electrical tape, insulate all round edge of battery
Solder the leads onto the new battery - note polarity. Red wire to +, black wire to -.
Using more insulating tape, wrap battery so that all exposed metal is covered.
5. put new battery into laptop (reverse steps 1-3)
6. start up computer, error 192 has gone, but still shows 161, 163. Select OK.
7. reset date & time, and OK
8. when screen shows 'O / I' restart laptop using on/off switch at side.
Good luck and thanks for using FixYa!!
Mar 05, 2009 | IBM ThinkPad T21 Notebook
Need code to boot up
You need a password. Try to remove cmos battery for a few minutes then replace battery then set date and time. This will defeat 2 of the three passwords. The IBM manual describes this process. If the Lock still appears then you may need an EEPROM reader some wire and a soldering iron.
http://www-307.ibm.com/pc/support/site.wss/product.do?subcategoryind=0&familyind=50224&brandind=10&doccategoryind=0&modelind=70454&doctypeind=3&validate=true&partnumberind=0&sitestyle=lenovo&template=%2Fproductpage%2Flandingpages%2FproductPageLandingPage.vm&operatingsystemind=52875&machineind=58997
Feb 21, 2009 | IBM ThinkPad 600E 2645 Notebook
IBM ThinkPad 600E 2645 PC
the following data is from the hardware maintenance manual for the thinkpad 600 series and is readily available from http://www.lenovo.com/support
Symptom or error FRU or action, in
sequence
161
Dead battery.
1. Go to “Checking the
backup battery” on
page 12.
2. Backup battery.
3. System board.
163
2. System board.
173
Configuration data was lost.
1. Select OK in the error
screen; then set the
time and date.
2. Backup battery.
3. System board.
192
Fan error.
1. Go to “Testing the
computer” on
page 7.
2. Measure the voltage of
the backup battery. If
the voltage is not
correct, replace the
backup battery.
3. Fan.
4. System board.
Oct 03, 2008 | IBM ThinkPad 600E 2645 Notebook
Ibm 600e
I had exactly the same problem and once i replaced my cmos battery it cleared the problem.
you can find lots of good instructions on here to tell you how to replace the cmos battery
Sep 14, 2008 | IBM ThinkPad 600E 2645 Notebook
Thinkpad 600E
Error 19990301 on a Thinkpad 600 usually indicates that the hard drive is not properly connected, and error code 19990305 signifies "no bootable device". So, it's the hard drive.
First of all, I would try removing and replacing the drive to see if that cures it. You can get the service manual from Lenovo at http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=LWIK-3SYPX2
If this doesn't fix it, the hard drive is faulty. However, small size hard drives (10 or 20Gb) which suit these older machines are very cheap on eBay.
Dec 18, 2007 | IBM ThinkPad 600E 2645 Notebook
Open Questions:
ibm thinkpad does not boot My IBM Thinkpad 600 (Type 2645-310) stops and hang during bootup. What happens is: 1. LED test, then green Power on and orange battery/charging 3. RAM OK (Responds when I take out /put in different amount of RAM and displays correctly. I have 128 + 32 removable, + 32 internal not possible to take out) 2. I can hear fan, CD drive and evt diskette drive. If I use diskette drive the LED wil give 1 blink, if I use CD drive it will give 14 blink. 3. No cursor seen, but this is displayed: Upper left show the amount of RAM present: 196032 KB OK Upper right IBMs logo in blue; IBM Lower left shows "ThinkPad(R)" in large letters and red dot over "i". 4. Then a "rrrrrr" sound from the loudspeakers after a while, this is in fact 28 clicks shortly after each other. Then nothing more happens. Diskette and CD drive is OK (But can not be used because bootup is never finished). I hear CD speed up and then down again but nothing more happens. No effect in booting with bootable diskette or CD, "Live Linux" CD or else. Backup battery OK (3V) and if I take it out I will be asked for correct date and time when Power on. I can then use keyboard or TrackPoint to set date and time, and after that hangup at the usual point. Starting without battery, HDD, CD drive and removable memory sticks makes no difference in symptoms. Pressing and holding F1 before and during poweron and startup (in order to enter BIOS and selftest) has no effect. I could not find help on IBMs home page, but maybe I did not look at the right place. Is somebody able to help me?
Feb 28, 2017 | IBM ThinkPad 600E 2645 Notebook
See all IBM ThinkPad 600E 2645 Notebook Questions
IBM ThinkPad 600E 2645 Notebook Logo
517 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
