Our GE Profile Deluxe washer is not draining
How do we get our GE Profile Deluxe washer to drain the water? The drain hose is kinked, while the washer is full of water. What should we do? Help!!
  • Anonymous Mar 24, 2014
    Will drain water out
  • 283 Answers
Your post says "drain hose is kinked". I assume you meant NOT kinked. You didn't leave a model # so it's difficult to advise. If it's a top loader set it to spin and listen for the drain pump sound. If you hear just a dull hum it's probably stuck with something in it.
Use a shop vac to get the water out. Pull the front off and remove the hoses from the pump. Look into the inlet and you'll see the object.
Posted on Jan 06, 2008
6ya staff
SOURCE:
GE Profile model WPRE6100 only spins slow....
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
INSTRUCTION BELOW
  • A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  • 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  • 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
  • 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  • 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall
  • thanks and good luck.
    Oct 02, 2010 | GE Profile WPRE6100G Top Load Washer
    GE top load washer will not advance to drain and spin
    Apr 15, 2010 | GE Profile WPRE6100G Top Load Washer
    The GE Profile Dishwasher does not drain completely. The bottom drain shows no obvious clog and the screens are clear. The overflow drain in the back of the washers the only reason the dishwasher does not...
    Uncouple the drain hose connection under the sink and use a wet/dry vacuum to **** out the drain hose and the stub on the sink drain plumbing to clear any possible clogs. There may be a blocked check valve near the pump that might have to be cleaned or replaced. Check the hose itself for any kinks or collapsed section. There might be a damaged drain impeller on the pump. Hope this helps!
    Mar 11, 2010 | GE Profile PDW8400J Built-in Dishwasher
    My washer keeps giving the message that the washer wont drain. Check the lines for kinks, etc. I have removed the back of the washer, checked the pump and all of the drain hoses, there is no blockage. The...
    you may want to look at that pump again
    for that model is rated at 8.5 ft
    so it should be moving that water right along
    when you have the pump hoses off put the unit in drain and watch the impella, it is quite possible stripped.
    Oct 15, 2009 | GE Profile WPRE6100G Top Load Washer
    GE Drain Hose
    Hi, Does this washer have to pump the water up into a drain? If it is possible, it would be better for the machine if you can bring the drin pipe closer to the washer. I know it is not always a possibilty. The longer the drain hose, the harder it is on the washer and sometimes the cloths don't spin out as dry as they will with a short drain hose.
    Vic
    Jun 20, 2009 | GE Profile WPRE6100G Top Load Washer
    Washer will not drain says check for kinks in hose
    Check the following to address this issue.
    1. Clogged drain line or water pump
    Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
    2. Water Pump
    If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
    Jun 04, 2009 | GE Profile WPRE6100G Top Load Washer
    Ge washer # WBVH6240FWW
    We have a GE washing machine that works fine with no load, but will not finish the cycle with a full load.
    Aug 15, 2008 | GE Profile Prodigy WPSE4200A
    GE PROFILE
    It sounds like your drain hose is kinked or blocked, or maybe the pipe that the drain hose drains into is blocked. Somehow water is now being allowed to get out of the machine at the end of the cycle and is staying in the machine. Check those hoses and pipes.
    Jul 11, 2008 | GE Profile Harmony DPGT750EC Electric...
    Washing Machines Logo
    150 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Marvin
    Marvin
