the screen turns off after a long period of use and wont turn back on until having been unplugged for an extended period of time. Do you think this is an overheating malfunction (although it does not appear to be overheated), or a power plug issue?
ferraric, You're halfway there! Now all you need to do is find the "THERMALLY INTERMITTANT" and "COLD/FROSTED LOOKING" solder joint on the power supply (switch-mode-power-supply) printed circuit board. Check all the larger and more weighty components first, including power transistors. I'm sure that the web has some pic's of what they look like! The cause of them going BAD is what is known as Thermal cycling! Hot to cold, Hot to cold. You may need a magnifying glass or an inspection microscope to view your printed circuit board! Visit YOUTUBE for disassembly vids and you better have a digital cam to document the teardown BEFORE removing plugs from board-mounted connectors. Good luck! louie12fix or aka 12fix louie
Was this helpful?
Yes
No
Popular Solutions for Samsung SyncMaster 940MW 19"
Samsung 940 MW. The set controls and remote do not work. Power up externally,the green light steady,...
(More)
Samsung 940 MW. The set controls and remote do not work. Power up externally,the green light steady, TV on but not able to change channel etc. Power off and on. same symptoms.
when switched on very faint image appears centre screen then moves to left and dissapears. nothing...
(More)
when switched on very faint image appears centre screen then moves to left and dissapears. nothing else appears on screen totally blank,checked caps etc no visible damage .
why there is a almost an invisible "black line" comming from the bottom of my SAMSUN...
(More)
why there is a almost an invisible "black line" comming from the bottom of my SAMSUN syncMaster 940MW LCDtv ?
