Question about Toshiba 55H70 55" Rear Projection Television
Lite in the front of the TV when you turn on keeps blinking and no picture.
I unplugged the TV power supply cord and reconnected it after a little while the light still kept blinking couldn't get it to come on. After setting up a small TV which works fine with the satellite connection, the next morning turned the big Toshiba back on to see if it would come on and play, it did for couple of daysday then went black again with the blinking light have done that twice now by leaving it sit overnight and again it worked fine. it is working now againthis but don't know for how long before blinks again.
No picture power light blinks
  • 1 more comment
  • hal S Jan 06, 2008
    The above is not my exact problem..my set simply has no picture and does have sound but the power light blinks I have not unplugged it because I need help moving the set..should I unplug it and if that doesn't work what do I do next?
    I got the set unplugged and powered up the light is not blinking and still have no picture but there is a ticking sound coming from inside the TV when the power is on
    Well any ideas on what next? who do I call do repair people exists that will trouble shoot and fix on site??
    Novelist:
    Champion:
  • 211 Answers
I am assuming the problem may be heat related, since the set works after cooling and being unplugged for a period of time. If this is something you are going to work on, I will suggest a pattern that we use at our shop to troubleshoot these type of problems.
Tools Needed:
, Can of freeze spray ( component cooler ) can be purchased at Radio Shack of any electronic supply store. Hair Dryer, Phillips Screw Driver or screw gun, soldering iron, solder.
Troubleshooting instruction:
1) Unplug the set from the wall/power
2) remove the back of the set ( bottom panel cover)
3) plug the set back in the wall and power up the ( turn it on )
4) with a hair dryer ( and not touching part of the inside of the set) turn the hair dryer on and blow hot air inside the set for at least 20 minutes or until the set quits
5)If set shuts down ( quits), then use the freeze spray to cool the boards by spraying. Do one board at a time to isolate the board. After cooling one board, try turning the set back on, if the TV starts, you have isolated the problem board. If not spray a second board and repeat the prosses for all board until the set starts so you can isolate the board.
6) Once you have isolated the proper problem board, you'll need to isolte the bad part ( ic, transistor, capacitor, etc). Again using the hair dryer, heat the board until the set shuts off. Then using your freeze spray, spay a small part of the board and see if the set starts working properly by switching the set on. With some time, you'll isole the problem part and the it's time to remove the bad part and simply change it. Remember to always unplug the set from the wall before touching anything inside or changing parts.
Additional Suggestions and PreCautions:
Your problem is most likely a filter Capacitor, moreso than a IC or Transistor.
Rember to use extreame caution when working inside the tv and please know that Freeze Spray freezes everything it comes in contact with including fingers, eyeballs and any skin part.
Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 06, 2008
  • Ed Meshechek
    Ed Meshechek Jan 06, 2008
    The ticking sound indicates the power supply is not receiving proper voltage to turn the circuits on. Again, it sounds like a main filter capacitor in the power supply. Keep me posted
    Ed
    NC Electronic
    Mills, Wyoming
  • Ed Meshechek
    If this is not something you can fix on your own, you will need to call a repair shop in your area. As for on sight ( home service ), there are still shops that offer them, but that is getting farther and fewer between due to cost and just the fact that most problems can't be fixed in home anymore ( no one can carry all the boards needed to fix everything ). Being a Toshiba, you should look in your owners manuel and find the 800 number to contact Toshiba Customer Support and ask for a local Toshiba Repair Center in your area.
    You can also obtain assistance on the web by accessing Toshibas web sight.www.Toshiba.com
    Ed
    NC Electronic
    Mills, Wyoming
    Genius:
  • 1,153 Answers
The blinking is giving you an error. Even thou you say your TV is working fine, there is something wrong. It could be anything from the convergence(like Color problems slightly out of line) or Sound problems, or you may have problems just in the power supply. Could you remember the set acting funny like in the past? If so do you remember what went wrong or what gliched? This could tell you what is going on now. If none of this it could be a capacitor in the Power supply.
I have a mitsubishi wd-62525 the power light keeps blinking, and i can't get picture. i unpluge it than want 2min than it stop blinking and i can turn to tv on and get a picture than after 30-40mi
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 06, 2012 | Mitsubishi WD-62525 62" Rear Projection...
I HAVE A PANASONIC TH-50PX75U TV THAT AFTER UNPLUGGING AND REPLUGGING THE SET IT WILL NOT TURN ON. THE RED LIGHT IN THE FRONT BLINKS, BUT NO PICTURE OR SOUND. I CHANGED THE BATTERIES IN THE REMOTE BUT IT...
The tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
Feb 05, 2011 | Panasonic TH-50PX75U Plasma HDTV
Samsung LA40A550 no picture and sound
Power supply board is dead.That the board,the power a/c cord go into it.Replaced the power supply board will solved ur tv power lite LED light indicator blinking and ur tv power will be stable and work again.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jun 04, 2010 | Samsung LA40A550 40 in. HD-Ready LCD TV
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
After turning on TV, lamp light blinks but no picture
IF IT SHUTS DOWN TO STANDBY, THEN DIGITAL BAORD IS BAD, IF IT JUST KEEPS CYCLING ON/OFF THEN YOU NEED A POWER SUPPLY, BALLAST AND PROBABLY LAMP
Dec 30, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
My picture shut off. Power lite clicks, blinks,no picture
how many times is the power light blinking as thats a error code. 3 blinks is the most famous which means convergence circuit failure.
Oct 26, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Q510, Ta1316 is your sync processor and probably the problem you're having here. It's a common one for this unit and you could pull the board and check the solder connections it has with the foil - - but you may need to replace it...
Nov 05, 2007 | Toshiba 50H81 50" Rear Projection...
MODLE NUMBER WS-55511
Missing voltage = open fuse in power supply?? soldered-in
pico fuse?
Does light blink continuos up front?
Can you hit power again with same result or must unplug/plug
AC cord??
Oct 24, 2007 | Mitsubishi WS-55515 55" Rear Projection...
Toshiba 55H70 55" Rear Projection Television Logo
89 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
