Maytag MSD2756G Side by Side Refrigerator
Problem for Maytag MSD2756G Side by Side Refrigerator
Food is freezing on left side of refrig and not so
By christy556 on Nov 09, 2009
food is freezing on left side of refrig and not so cold on right
Best Solution
posted on Nov 09, 2009
Helpful)
jumptrout51
Rank: Guru  Maytag Expert
Rating: 89%, 1021 votes
Check the back wall of the freezer section for any ice buildup. This would be from a failure to defrost and requires parts.
Check the freezer side for the evaporator fan motor. Is the fan motor running?
If not a fan motor is needed.
If there is ice on the back wall of the freezer you can activate the defrost control by turning the cold control thermostat OFF then back ON "3" times.
Once you activate the control listen closely in the freezer side for a sizzling sound. This would indicate the defrost thermostat and defrost heater are good and the defrost timer needs replacing. If there is no sizzling sound after 20 minutes,the defrost thermostat and possibly the defrost heater need replacing.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Maytag MSD2756G Side by Side
Questions and Unsolved Problems for Maytag MSD2756G Side by Side
Do you recommend Maytag MSD2756G Side by Side Refrigerator?
Answer
Answer
I have a Maytag Side-by-side Ref/Freezer Model MSD2458GE. The compressor went out and just had it... (More)
Answer
Ice maker stopped making ice. It dispenses ice and water although the water is warmer then normal.... (More)
Answer
msd2572vew delivered 11/19/2009; Ice is making fine, but when I push water button nothing happens
Answer
Freezer seems to be working but refrigerator is warmer
Answer
The freezer defrosts enough so that the ice melts and clumps up in the ice dispenser and any food on... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Maytag MSD2756G Side by Side...:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
