Question about Nokia N95 Cellular Phone
Not enough rings
My phone automatically goes to voice mail after 2 rings, how do I make the rings longer so I have a chance to answer before the phone does?
    Scholar:
  • 79 Answers
Check the settings in call divert.
Posted on Jan 07, 2008
6ya staff
SOURCE:
Canon mf5770 not receiving faxes
Most fax machines allow you to set the number of times the phone rings before it automatically answers the phone. So if you phone goes to voice mail after 4 rings and the fax machine is set to start the fax after the 5th ring it will never receive the faxes because the call went to voice mail. Good Luck
Dec 05, 2013 | Office Equipment & Supplies
1)How can i stop the automatic transfer of calls to another extension phone when i have not taken the call that should be for me... 2) how can i program my switchboard into voice mail where they can...
It takes so long to get an answer because you asked two different and complex questions. 1. Where do you want the call to go? It's related to question #2, but the forward either works or it doesn't...that's what the FWD/DND button is for. Your delay before it goes can ge adjusted. In our installations, we use CF-No Answer and set the ring count to 4. If you're on the phone and another call comes in, you can see it from the display and hear the soft ring. You can either answer it or ignore it and it will go to somewhere else (generally voice mail).
As far as your second question, if you have voice mail, an auto attendant can be part of the system. It's programmed at installaton to pick up incoming calls and follow a menu system called Custom service. It also functions as your voice mail system as mentioned in #1.
Carl
Mar 08, 2011 | Panasonic KX-T7633 Corded Phone
It only rings 2x before it goes to voice mail
contact your service provider and tell them how many rings you want it set to before it goes to mess bank
Apr 20, 2010 | Pantech Slate Cell Phone
Nor ringing long enough before going to voice mail
Try going into your settings/call settings/call divert.
Go into Call Divert and cancel all diverts.
This should solve your problem.
Aug 26, 2009 | Nokia N73 Cellular Phone
Need more rings
You have to change the rings from the voice mail server. If you don't know your way around the server, its best to get a local NEC tech although it is fairly simple to navigate. Depends on your skill. Typical default password for the server is NEC
Oct 16, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Call Waiting
THere are two answers to you question, depending on certain options and conditions.
First, where is the voice mail and where is the call waiting coming from?
1. If Voice Mail (VM) is located in the central office and you have a destination for call forward BUSY/NO ANSWER it will go to CO VM.
2. If Voice Mail on premise (Partner Mail), and you have CF BUSY/NO ANSWER set on your phone, it will go to voice mail....IF the call waiting is coming from another line. The CF and ring count is set in Partner system programming.
3. If you have call waiting coming on the same phone line and don't have CO VM, then you have no voice mail.
My CO codes for VM are 72# for Call Forwarding and *92 for CF Busy.
As Always, YMMV
Carl
Sep 14, 2008 | Avaya Partner 34B Corded Phone
Change the amount of times it rings before goes to V-mail
In Coverage path form for voice mail
COVERAGE CRITERIA
Don't Answer? y y Number of Rings: 2
COVERAGE POINTS
Point1: h2 Rng: 1
you can change Number of rings,Rng options
Jan 17, 2008 | NorStar T7316E Corded Phone
LG Chocolate, De-activate Voice Mail?
There isn't a way to disable voicemail cause it automatically fowards the call.
Oct 12, 2007 | LG CHOCOLATE VX8500 Cellular Phone
Call will not Transfer to Voice Mail
Typically you want your phone system to ring your phones (say extension 10, 11 and 15) and then if no one answers after so many rings the call is transfered to the port the voice mail is on (let's say it's port 16) The voice mail is set to answer right away but does not "ring" until the call is transfered to it. This way (at 4 rings) if a call comes in on line 1 and you answer after 3 rings but a call comes in on line 2 at the same time, the first ring on line 2 will not make the total = 4 and set off the voice mail. I would guess the port at your voice mail is not set to ring and nothing is set up to transfer calls to your voice mail. Did you set this up yourself? How did you program the phone system?
Aug 21, 2007 | Toshiba Stratagy 4 Lite Voicemail System...
Nokia N95 Cellular Phone Logo
138 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
Zaid Anarwala
Zaid Anarwala
