All of a sudden it will not send a fax. I called the fax number and get the chirp, but my C6180 is not sending. I get the message to check my connections.
That has happened to me on several HP's I have owned try replacing the cord connecting to the phone line if that does not help look where the socket is for the phone jack and with a flashlight check to see if the 4 wires are sticking up they are very small and bend easily see if they are touching if they are then use a safety pin to straighten out the wire. Also if you have a splitter thay connects it to the phone line try removing the splitter and see if it works. If you still have a problem go to www.hp.com select your printer and use auto detect and let it trouble shoot the problem for you. There is also free online help with the problem as well. And if you register it it will be under warrenty and will save you from having to pay for the repair.
Was this helpful?
Yes
No
Popular Solutions for HP Photosmart C6180 All-In-One
Need a description of functions for the buttons on the front panel display for the HP Photosmart...
(More)
Need a description of functions for the buttons on the front panel display for the HP Photosmart C180 Printer.Need a copy of the manual.
HP Photosmart C6180 All- In- One Printer keep coming up with Ink System Failure: Error: 0xc05d0381 I...
(More)
HP Photosmart C6180 All- In- One Printer keep coming up with Ink System Failure: Error: 0xc05d0381 I do what it tells me and it still doesnt work.
Too much pink in pictures. Just started doing this, for no apparent reason. Have changed ink...no...
(More)
Too much pink in pictures. Just started doing this, for no apparent reason. Have changed ink...no difference...Have changed computers...OS...no change. Does this no matter what software I am using... Has to be in the printer. What has happened and can it be fixed
