Question about Garmin iQue 3200 GPS Receiver
IQU 3200 no longer finding any sattelites
It was working fine and I have owned it since new. All of a sudden, even outside on a sunny day, the unit will not find even a hint of a sattelite. I'm about ready to try and open it to see if a wire is broken or something.
For the record I have reset it and resynched it multiple times.
  • ben1923 Sep 24, 2008
    I have the exact same problem. Any luck getting this fixed?
  • Anonymous Mar 06, 2009
    although mine did get a weak signal from a single satellite, briefly. This happened once before, several months ago, then it magically corrected itself.
Try using and external antenna. If that works your internal antenna is kaput.
Posted on Feb 02, 2010
6ya staff
SOURCE:
Coleman 8000 compressor only comes on and cools when cool outside like in Am or late pm
Clean the coil inside and outside. try putting it in a window on a shady side of the house. I worked on a outside unit wher it was 90degrees outside but 107 degrees where it was in a hot location, close to road on sunny side of house.
Jul 28, 2012 | Dometic Rooftop RV Air Conditioner
I have a Lowrance iway 500c. When I power it up, it does not find my current location. It comes up with a location in Florida where my father-in-law was in Florida with the unit earlier this year. . When I...
When was the last time you went into the your settings and update your software or configured the unit? On cloudy days you can't do this. On a bright sunny day go outside and try this.
Dec 14, 2009 | Lowrance Iway 500c GPS Receiver
1994 Pontiac Grand Am gets water pooling on the floor even on sunny days-front driver's side. Windshield is fine. No smell or color to the water. Level of water increases the longer it sits.
You need to check under the car for rust holes in the chassis or up under the door sills or wheel wells. Its that or a chassis seal is gone.
Nov 04, 2009 | 1994 Pontiac Grand Am
Maxtor 3200 was working fine. Suddenly my
Try connecting it to another computer.
If it is not detected, then either the disk-drive "inside" the unit is dead, or the "adapter" (USB-to-Disk-Drive) inside the unit is dead.
If the latter, disassemble the case, remove the disk-drive, and attach it as an "internal" hard-drive to your computer.
Nov 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Personal Storage devie model 3200-computer not recognizing
sounds like the hard drive inside the unit has crapped out. you may need to replace the HD (there maybe compatability issues in doing that).
or see if its under warranty. or buy a new one and have someone extract the info from the old drive
Jun 28, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Sony DCR HC19e Sunlight problem
Problem can be fixed by Reset the camera. Just push Reset switch with ballpen and camera will power up again. adjust the date etc and have fun.
Jul 25, 2008 | Sony DCR-HC19E Mini DV Digital Camcorder
GARMIN C330 WILL NOT LOCATE SATTELITE
Have you tried a Master Reset? It may help, but it WILL ERASE ALL OF YOUR FAVORITES. To do a Master Reset, turn the unit off. Press and hold the bottom right of the screen, then press and release the power button. Keep pressing the screen until the unit asks if you are sure you want to reset. Follow the prompts.
Feb 09, 2008 | Garmin Nuvi 370
Garmin iQue 3200 GPS Receiver Logo
60 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Sheldon Dedek
Janelle Schoonover
Janelle Schoonover
Are you a Garmin GPS Expert? Answer questions, earn points and help others
