Question about Canon PIXMA iP4000 InkJet Photo Printer
Multiple Problems Printing
This printer has not been used in a number of years and I recently tried to set it up and print off photos. After many cleanings, deep cleanings and nozzle checks and replacing the ink cartridges, I am now able to print off a photograph. Before all of these maintenance routines, I could only print vague colored lines with no resemblance of a photograph.
The resulting photograph has multiple problems that I am unable to solve. In black sections on the image printed, large plain black sections seems to bleed into other colors slightly on the border of the black color. Some shades of plain red sections print out blotchy and brownish red, while other reds print out fine. There are also horizontal lines going through the whole image, with larger horizontal bands composed of red and blue lines every 1/4 inch and in between those bands are smaller lines of blue and red bands alternating every millimeter.
I have also had trouble with the nozzle check function. After doing a nozzle check there are some horizontal white lines still going through some of the test stripes. The 6BK does not print out correctly as a gray color it only prints some gray lines, but not many at all. Even after replacing the cartridge and performing at least 20 cleanings.
This nozzle check also suggests I need to align the print head. This function of alignment is not able to be completed on my printer. It always ends in an error ("an error occurred during automatic print head alignment") and does not print out anything. It seems to have difficulty bringing the paper from the paper feed section into the printer, it grabs the paper brings it in and then backs out and then brings it in fast and shoots the paper out the paper output section. I have attempted to do the alignment both from the computer and manually from the printer. Once during an attempt to complete the print head alignment, it printed 3 rows of 6 columns and then spit the paper out. This chart does not look similar to those listed in the user's manual, so I do not think that the print heads are aligned still.
Any suggestions on what to try next?
  • Anonymous Mar 18, 2014
    black print is not of consistent standard/quality. Lines of missing sections etc.
Replace the print head, and all should be just fine.
Posted on Jan 24, 2008
6ya staff
SOURCE:
C6180 -- I've had this printer for several years with no printing problems. However recently it has objected to printing photos although using the same HP photo paper as before. It starts to print and then...
please specify that u r getting the message on printer or on computer screen the paper is really jammed in the printer.
better do a power drain > turn off the printer and unplug the usb cable and power cable from the printer and then press and hold the power button of the printer for 30 seconds and then release. repeate the steps 3-4 times. then restart the printer and try printing from the computer, if the issue persists then restart the computer and try printing. if then also the issue persists u need to clean the rollers of the printer and it will certainely resolve the issue.
mail me [email protected]
Jan 15, 2011 | HP Photosmart C6180 All-In-One InkJet...
Problems printing photos
Are you using HP cartridges with the printer? there are known problems with non hp cartridges in hp printers.
Jul 21, 2008 | Apple HP Officejet G85xi InkJet Printer
MY printer stopped working from on day to the next...the problem is when I print out a photo from IPhoto or Preview on my IMac OSX10.4.11 it starts with a large margin which doesn't allow for the complete...
Hello
Large photos are printed differently than regular photos.
Photos that have large resolutions or are best when printed in larger sizes are sometimes printed on multiple pages. Printing the photo on two or more pages requires setting up the printing options so that the printer recognizes how the photo should print and which areas to stop printing on each page.
Open the photo in iphoto
Select "File" and scroll down the list until reaching "Print". Click on "Print" and wait for the printing set up options. Some programs require selecting "Set up" or "Print set up" instead of "Print." Make sure the set up options are brought up according to the program.
Select "Time Imageable Table" or similar options in the program. If there is not an option with a similar title, look over the various titles and any pictures that come with the titles and see if the pictures show multiple pages or only a single page. Click on the options that allow printing one photo on multiple pages.
Select overlap options, which give margins so that connecting the pages forms the picture. Overlap around 1/2 inch or so.
Print the photo. The number of pages should match the set up options selected under the imageable table.
Nov 17, 2010 | Epson Stylus Photo RX600 All-In-One InkJet...
Slow printing
depends on what your printing, clarify more what your printing, text or a photo
if a photo, what is the dpi set at, if the file is multiple mb's then it will take longer
hope this helps
Apr 30, 2010 | HP Inkjet 2600 Printer
Trying to print multiple copies and only one copy prints
The setting of quick print is as same as print. So you should check the print settings.
Click File->Print, in Copies Textbox, enter the number of copies.
Hope that help
Nov 05, 2017 | HP DeskJet 6122 InkJet Printer
Epson Stylus Photo R260 doesn't complete prints
Make sure that you have the correct paper size set in your printer settings. Incorrect size would cause the problem you describe.
Sep 17, 2008 | Epson Stylus Photo R260 InkJet Printer
please specify what printer, model,
Jul 23, 2008 | Apple HP Officejet G85xi InkJet Printer
Printing in color
hi
often the printer 'driver' settings on your printer are set to greyscale only
on the pc open the control panel, printers
right click on the printer and select properties
open the control for the printer and go to the printing preferences (on the general tab)
on the next window (main) look down and ensure the setting is set to colour (not greyscale)
ok out and try printing again
these settings are from my iP5000 and should be similar
try looking in the preferences for similar options
D
Nov 21, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Lost reverse side printing option
Yepperz
The double sided printing option relies on Status monitor working correctly. If information cannot travel from the printer to the computer, the option will be greyed out.
Make sure you have a direct connection to the computer without any hubs. If that doesn't work, try the following.
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS
2. Right click on your Epson printer name, and click CANCEL ALL DOCUMENTS.
3. Confirm cancelling all documents.
4. Right click on the Printer again, and select DELETE.
1) Click on START, SETTINGS and CONTROL PANEL.
2) Double click on the SYSTEM folder and select the Device Manager tab.
3) Click on the "+" for "Universal Serial Bus Controller"
4) Right click on "USB Printing Support" and select "Uninstall" and confirm it
5) Disconnect the USB cable and reconnect it.
Try Printing
Sep 07, 2007 | Epson Stylus R265 InkJet Photo Printer
Canon PIXMA iP4000 InkJet Photo Printer Logo
698 people viewed this question
Clive
Clive
old marine
old marine
Ekse
