Kenmore 22422 Top Load Washer
Problem for Kenmore 22422 Top Load Washer
Tub is out of balance and leaking water
By rjflsts97 on Nov 09, 2009
tub is out of balance and leaking water. Seems like what holds the tub in place is broken.When the tub is off center and filling with water it misses the tub. I can move the tub when it's empty alot more now compared to 6 months ago. Any help would be appreciated. Ron
Clarification Request
Posted by oldguy5 on Nov 09, 2009
Can you provide the exact Make, Model and Kenmore model number? Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines. If this is a basic Kenmore top load, direct drive, it sounds like the drive block / spin tube but I cannot provide a solution without the full model number.
Solution #1
posted on Nov 16, 2009
Not Rated)
drallim
Rank: Guru  Kenmore Washers & Dryers  Expert
Rating: 87%, 704 votes
Open the top and observe the motion dampers in several corners--shake the tub, it should return to center by itself. Some are a small shock-absorber looking devices, others are spring balanced with flat plates rubbing together for damping. Sometimes the plates can climb on top of each other--push the tub to the side to bring the plates together properly. If you need any parts, go to: SearsPartsDirect.com They have drawings showing the relationship of parts as well as the part numbers for ordering.
Was this helpful?
Yes
No
Popular Solutions for Kenmore 22422 Top Load Washer
Questions and Unsolved Problems for Kenmore 22422 Top Load Washer
Do you recommend Kenmore 22422 Top Load Washer?
Answer
Answer
rattle under the agritator. sound like coins, mails or some other tiny piece of metal.
Answer
Hello, Have a Kenmore series 70 (capacity plus). The washer won't stopped filling unless I stop it.... (More)
Answer
When I try to start the machine it will not fill with water or agitate it will do the spin cycle. It... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kenmore 22422 Top Load Washer:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14935
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
