The fridge was working fine until yesterday morining and as a sudden, things have started to melt in the freezer and no cold air inside it at all. I got the fridge as a resale, and I don't have the manual
If there is no frost build up on the inside rear freezer wall , the the problem is the overload/relay ( pt # 12002784 ) which is plugged onto the side of the compressor and is easily replaceable . Only 3 wires are connected . If there is a frost build up , then reply back , for the instructions on how to check for defective parts in the defrost area (only 3 ) .
The defrost timer may have stopped in the defrost cycle and if it isn't getting out of it then it needs to be replaced. You can fins the defrost timer at the back it is a box about 6 X 4 X 2 inches you can use a slotted screw driver and advance the timer see if everything works. If it does work then replace the timer or see if it comes out of the defrost cycle within 30 minutes.
Was this helpful?
Yes
No
Popular Solutions for Jenn-Air JCD2389G Side by Side
Changed filter 2 weeks ago and now the "Change Filter" light has come on. How do we shut...
(More)
Changed filter 2 weeks ago and now the "Change Filter" light has come on. How do we shut off the light?
i need to replace the defrost timer in a jenn-air side-by-side and can't figure out how to get...
(More)
i need to replace the defrost timer in a jenn-air side-by-side and can't figure out how to get access to the connector
We have a Jenn-Air side by side Ref/Frez it is working fine but water runs from under the unit. It...
(More)
We have a Jenn-Air side by side Ref/Frez it is working fine but water runs from under the unit. It is in the garage so not a major problem. Model #JCD2389GE
