Question about Kitchen Ranges
GE gas slide in range JGSP31GER blanking out
Oven and broiler is ok through setting temp then when entering bake or broil starts blinking 100 then (red display)
blanks out. For a while after that trying to hit bake or broil again won't respond. When it does later on the same
problem arises. Today it blinked 100 and after you could here the gas heating up the red part of the display
blanked out again, and gas turned off. is there a simple check to perform here rather than replace the $250-$300 ERC display?
  • 126 Answers
SOURCE: Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Posted on Dec 10, 2007
SOURCE: GE JCB909 Range - Blank display
The problem was not with the stove, it was with the electrical box - it was wired incorrectly.
Even though power was getting through it was not the way it should be. Electrician made repairs and stove appears to be functioning correctly.
Posted on Jun 26, 2008
docjohn174
  • 943 Answers
SOURCE: the oven broiler work but the baking part doesent.
hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
Posted on Sep 30, 2008
SOURCE: Instructions for Frigidaire oven missing.
I found the manual online. Apparently my unit is malfunctioning and should work by just pressing bake temp and then selecting the temp...
Posted on Dec 03, 2008
  • 71 Answers
SOURCE: Oven will not bake, but broil works
the bake ignitor is most likley bad
Posted on Dec 24, 2008
GE Profile gas range - Model Number removed by previous owners. Black slide in range with warming drawer - 5-10 years old. Digital oven controls on left side Broil and Bake functions are reversed. When...
Unplug the range.
I would open the control console and locate the BAKE/BROIL terminals on the Oven control. I would reverse the wires,plug the range in and try again.
Sounds to me like someone has changed out a part and wired it wrong.
Jan 03, 2010 | GE Kitchen Ranges
Why does the surface burners and broiler light but not the oven burner on my Kenmore gas range? Kenmore gas range around 14 years old the model number is 362.7352192. We were using the oven and in the...
The oven gas valve coil has failed Need to replace. Go to repairclinic.com and put in the model and order the coil for the valve. It controls the gas valve.
Sep 11, 2009 | Kitchen Ranges
Bake does not work but broiler does.
OK, it is likley that the oven ignitor isn't working and needs to be replaced. To verify if this is the problem, when you turn on the oven to BAKE and set the temp at say, 350. Watch through the window, (or you can have the door open). Look at the bottom, back, center and see if you see a bright orange glow appearing under the bottom panel.
If you don't, that is why the oven won't lit the gas. There is an ignitor for both the broiler burner at the top and for the bake burner in the oven compartment.
The reason that the temp display reverts to 100 degrees is because that is the lowest default temp setting for the display and until the oven temp actually starts to increase, it won't change. So the temp display is working correctly for the BAKE function.
Here's a line drawing showing the part you may need. Ignitor Part # WB13T10045. The good news is that your oven uses the same ignitor for both the broiler and bake burner tubes, so you could swap them if you wish to confirm that is the problem before you go and order/buy a new one. These aren't cheap at $91 bucks, but you can shop around the web for a better price if you determine you need one.
Sometimes the ignitor burns out half way through but because it still lits/glows, people think it's OK, but it won't get hot enough to signal the gas valve to open and allow gas to ignite and get the oven cooking.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=JGS905SEK1SS&productCategoryId=0124250&brandId=3272&modelName=GAS-RANGE&diagramPageId=00001&componentDescription=GAS%20&%20BURNER%20PARTS&documentId=G6090295&backToLink=Return%20to%20Sub%20Components%20list
Hope this helps you out and remember to disconnect the oven from the electric power before performing any repair work. Best regards!
Aug 01, 2009 | GE Profile JGS968 Gas Kitchen Range
No Bake; everything else works
Hi, When you put the oven on bake, can you see the ignitor glowing but get no flame?
Sound like the ignitor might be getting weak and not opening the gas valve. Please let me know if this sounds like the problem.
It is common for the ignitor to go bad. Even if it glows, it can be bad.
Please let me know if I can assist you further.
Vic
May 31, 2009 | GE Profile JGS968 Gas Kitchen Range
My broiler works - but the oven does not - GE Dual Fuel range
Thanks for providing the full model number, which allows us to look up part numbers and see exploded views of your product.
Most likely the bake ignitor is bad (even if it still glows, it may not draw enough amperage to allow the gas safety valve to open). One way you can test this on your model is to swap out the broil ignitor for the bake ignitor, as they are the same part number on your model. (part number WB13T10045) The broiler is normally used much less than the oven, so the part does not fail very often on the broiler. You will have to take the cover off the floor of the oven, then the flame spreader, to reach the burner area. The ignitor is the rectangular part at the back, on the side of the burner. (only two wires to deal with) (By the way, for future reference, your model number ends is SS, as in stainless steel, not a 55)
Jan 15, 2009 | GE Profile JGSP44 Dual Fuel (Electric and...
GSP31GER GE gas slide in oven dosent work
I think you missed a letter at the beginning of your model number. (it is maybe a JGSP31GER ?) I would first test the broil, and see if that works. (I would guess that it does) Most likely the oven ignitor (part number WB13K5058 ) needs to be replaced. It is located under the floor of the oven right next to the burner. It is a round electric coil thing about 4 inches long. If you want to confirm that this part is bad before replacing it, (and the broiler works) you can take the ignitor off the broiler and install it in place of the oven ignitor. They are the same part number. Of course now your broiler and self clean will not work unless you replace the broiler's ignitor. This is not too difficult, maybe a 3 on a scale of 1 - 10. Should be a Fix-Ya for your slide in range!
Jan 01, 2009 | Kitchen Ranges
Hi...need help with my oven it won't heat up
If your surface burners work and the broiler operates normally, more than likely you have a failed igniter on your bake manifold. There are two separate igniters on your oven. One is for bake, and one is for broil. This is a common failure, due to the fact that the bake function gets used more often than broil. I found your part listed at repairclinic.com. Just type in your model number and the igniter is listed as item number 1990. For instructions on how to replace the igniter, click on the following link:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
Just make sure you turn off the gas and unplug the range before starting any repairs. If you require further assistance, please let me know. I hope this information is helpful to you.
Jul 13, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
GE Profile Spectra JGBP85
Yes, it could very well be an igniter. The igniter can still glow and not work. The reason being that the igniter (depending on type) needs to produce .25 to .37 amps in order for the gas valve to open. If this potential is never reached, the igniter will glow, but gas will never flow. Or, gas will eventually flow for a weak (slow) igniter and will take forever to ignite. Which could be the reason for your low bake temperature. The burner does not stay lit all the time during the bake cycle. It will cycle on and off as needed to maintain the oven temperature. If the igniter is taking a long time to relight the burner, it could take a long time to heat. The broiler has a separate igniter and probably doesn't get used as often as the bake igniter. You can test the theory by swapping the igniter between the bake and broil burners and see if the problem moves to the broiler. Make sure you secure power to the range BEFORE attempting to remove the igniter, however. You should not have to turn off the gas to do this. Everything should be accessible through the oven door and broiler. I tell you this, because a new igniter (depending on the type you have) can run as much as $100. It will probably be worth the effort just to be sure. I hope this helps you.
Jul 15, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge oven jpbp90
Ted, you probably have a bad ignitor. If you have a meter, you can do some checks to rule out the board. Take the back top panel off and on the board you will see four wires..from left to right they should read L1, neutral, broil and bake on the board. Broil and bake will be marked as BR and BA. Set the oven to 350 and press bake, you should have 120V from BA to Nuetral. If so your board is ok. You should also hear a click after pressing bake. 90% of the time it's the ignitor, part number WB13K0004. Be care when testing with live power. Catriver..post back.
Oct 15, 2006 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
132 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
