Question about Sony Handycam DCR-DVD201 DVD Camcorder
Е:61 :00 flashing on screen
And there is no clear picture like focus
  • mknodak Sep 25, 2008
    I cannot get my Sony Handycam to focus. There is a flashing E:61:00 in the top right corner of the screen. What do I do to fix it?
  • josievj Dec 22, 2008
    the screen is blurred and there is a E: 61:00 keep on flashing on the screen. pls tell me how to fix it.
    President:
  • 4,402 Answers
Www.fewin.com/sony/sony.htm
check out this site for the mavica FD73 solution.
The problem is the lense focus adjustment motor.
Better explained in the above web site.
The sudden impact of the camera frees up the
adjustment mechanisms. Thus the error: E:61:00
disappears. I just fixed my Sony Mavica MVC FD 73.
Posted on Jan 25, 2008
Focus is off
Check to make sure the focus screen is in properly
Aug 08, 2013 | Canon EOS Rebel XSi Digital Camera
Photos are fuzzy
as you take a picture ( scene w/o flash ) slightly press the snap button and wait till red or green box appear, if red box, out of focus. if green box in focus. when green box, make sure you and the focus are very still, then take a clear picture, pressing the button all the way. make sure no shaking as press button either.
Mar 17, 2010 | Samsung S760 Digital Camera
Sony Trinitron screen flashing
The picture tube is starting to fail. The increased screen voltage allows it to stabilize at the expense of color quality. Sorry to say, but it is time for a replacement.
Dan
Dec 17, 2009 | Sony Televison & Video
Pictures are appear blurry when reviewing them. I focus the camera object appears clear after I snap the picture it becomes blurry as it is being save for review.
Question : Why are my pictures out of focus (blurry)? Answer : This problem can occur for one or more reasons. Here are some common causes and suggested solutions.
  • The lens is dirty. Use a soft brush to remove dust and dirt. Wipe the lens gently with a soft, lint-free cloth or an untreated lens-cleaning tissue. Do not use cleaning solution unless it is designed specifically for camera lenses.
  • The subject was too close to the camera. Make sure that you are far enough away from your subject. Each camera has a recommended distance for normal, telephoto (zoom), wide-angle, and close-up pictures.
  • The subject was not within the effective range of the flash. Each camera has an effective flash range.
  • The camera did not focus or expose the picture correctly. For the best possible pictures, press the shutter button halfway and hold. When the Ready light or framing marks turn green, press the shutter button completely down to take the picture.
  • The LCD screen Preview feature was not used to take a picture in Close-Up mode. Always use the Preview feature in Close-Up mode to confirm focus and to frame the subject properly. If the Preview feature is not used, the LCD will not display an accurate view of the subject.
  • The subject or camera moved. Hold the camera very steady when taking a picture, or place the camera on a flat, stable surface. You may want to consider using a tripod or monopod.
Dec 08, 2009 | Kodak EasyShare Z740 Digital Camera
Half of the screen is clear and left side of the screen is blury
Its a Common Problem with Projection Tv's ~ If your flash focus is not correcting the problem, And It can Not be Adjusted in your service menu: under Manual Convergence, your IC chips and maybe a few resistoirs may have failed and need to be replaced!... onegeo
Jul 07, 2009 | Sony KP-46WT500 46" Rear Projection...
TV, RCA MOD # F19424, CTC 203U5, Picture blury
Focus and Screen. The focus control may help, just like focusing a set of binoculars or an old camera. Watch the picture on the TV, using a mirror can help and make an adjustment until the picture is as clear as you can get it. If it still is not clear it may mean that your picture tube is weak.
If you can avoid it, don't touch the Screen control. If you have, let me know and I can advise you on the proper way to adjust it.
Oct 09, 2008 | RCA Televison & Video
Focus
Focus control is on the Flyback there is 2 adjustments one is screen drive other is focus turn it untill you have clear picture.
Sep 03, 2008 | RCA F32450 32" TV
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Jul 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Powershot S1 Digital Camera: Flash won't fire
Make sure the camera is not in Document mode . Document takes a picture with added contrast so text stands out. Make sure the camera is not set to Infinity focus . When you select Infinity Focus, the camera automatically turns off the flash and auto focus so you get sharp, clear pictures. Make sure the camera is set to Fill, Auto, or Red Eye flash. See your camera manual for details about setting the flash.
Dec 31, 2005 | Canon PowerShot S1 IS Digital Camera
Sony Handycam DCR-DVD201 DVD Camcorder Logo
584 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
