Adaptec 2-in-1 Combo FireWire & USB 2.0 CardBus AdapterAUA-1422CS  Serial Adapter
Problem for Adaptec 2-in-1 Combo FireWire & USB 2.0 CardBus...
I have a combo cardbus card, when i put it in to
By stephenbaker on Nov 09, 2009
i have a combo cardbus card, when i put it in to the slot it turns the laptop off.
Clarification Request
Posted by skipsinclair on Nov 10, 2009
Sounds like either a bad card or a bent pin in the cardbus slot. Try another cardbus card, if the problem continues with the new card, then try to see if one of the pins has bent in the laptop - if it shorts out against another pin, I can imagine that causing a short that could shut down the laptop.
Solution #1
posted on Nov 10, 2009
Not Rated)
marked
Rank: Guru  Computer Networking  Expert
Rating: 86%, 929 votes
The combo cardbus is creating some type of conflict to your router and that one is a sign of compatibility issue so better if you just have the card replace....
Was this helpful?
Yes
No
Popular Solutions for Adaptec 2-in-1 Combo FireWire
Questions and Unsolved Problems for Adaptec 2-in-1 Combo FireWire
Do you recommend Adaptec 2-in-1 Combo FireWire & USB 2.0 CardBus AdapterAUA-1422CS (AUA1422CS) Serial Adapter?
Answer
Answer
I have the siemens xnd-1 for upload/download to the mxl panel and I'm using my usb cord but I cant... (More)
Answer
Serial adapter is not recognising weavepoint program Error message Comport not availablr
Answer
Sabrent HighSpeed 5-Port USB 2.0 PCI Card - USB 2.0, 4 External + 1 Internal, Type A, Plug... (More)
Answer
I am trying to get my usb port to work with an adapter for a 9 pin serial with my embroidery sewing... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Adaptec 2-in-1 Combo FireWire...:
Top Serial Adapter Experts
Rank: Guru Guru
Solutions: 3598
Experience: Semi retired, was network administrator, proficient with hardware, software, networks, CAD systems
Ask Me
Find more Serial Adapter Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
