Question about Philips DVDR3320 DVD Recorder/VCR
DVDrecorder not responding
Recorder is not responding to remote control or manual commands
  • crankybadger Apr 16, 2008
    My dvd player picture rolls as soon as its turned on without a disc. Will not respong to commands. The VCR part of it works perfectly still. Mine is a Magnavox.
  • 258 Answers
Try a power on reboot. hold the power button for 12 seconds until it reads "recover"
Rolling picture could be a loose cable or TV on the wrong channel.
Posted on Aug 14, 2008
During my recent transfer to a new flat i lost my remote control for my panasonic dvd recorder type DMR EH67. I bought a universal remote control but i did not have the full functions of my lost one. In my...
You can try changing the command mode of the (genuine Panasonic) remote itself, press and hold [ ENTER/OK ] and the number [ 3 ] button together for 5 - 10 seconds, then release. Then try the remote with the unit. If it still shows DVD 3 on its display, no matter which button is pressed, reset the main unit to factory default as outlined in the user manual (assuming this model recorder has a tuner, there would be channel buttons on the front - try pressing and holding [ CH/UP ] and [ CH/DOWN ] together - for 5 - 10 seconds, until 'SETUP' appears, then release). This may or may not restore your DVD unit to the default (DVD 1) command mode. (Don't forget to reset the remote back to DVD 1 if you do reset the main unit - press and hold [ ENTER/OK ] + the number [ 1 ] button together as above).
Your new remote may be set to DVD 1 by default while your unit is DVD 3 = different remote command modes.
May 02, 2011 | Panasonic DMR-EH67EG DVD Recorder/HDD...
Recorder is set to DVD command mode 1 and remote is set to DVD command mode 3 . Remote will not respond so i can not get to menu to reset. Is there any way around this problem
There is a manual for this model available in pdf format unless you have the original instruction book. Page 23 outlines 'command mode' where you can try pressing ENTER and the corresponding number buttons simultaneously on the remote for more than 3 seconds while pointing RC at the recorder. In your case, because your recorder is set to command mode 1 - press ENTER and 1 together on the remote. This should allow you back into the on-screen menu to revert the command mode back to 3 (which is the default) and it should work.
The online pdf manual for this model: unless you still have the original. Pages 22-24 show some of the setup procedures. The pdf is not very big so you can save it for future use if needed.
Feb 01, 2011 | Sony RDR-VX560 DVD Recorder/VCR
Non-functional remote control for Baseline DVD recorder
No do not try soldering the led. This is a led (Light Emitting Diode) It is supposed to look like that. You might have a bad IR sensor in the Recorder itself. The Ir sensor (Infared Sensor) receives commands from the remote and relays the command to the microprocessor in the recorder for processing. To make sure its the remote try a universal remote and program it for your dvd recorder and see if it takes commands of any sort. IR sensor are very cheap the only issue is installing it on the main board of the recorder.
Dec 02, 2009 | Televison & Video
Locked out of the menue ,Need to reset command mode
Indeed, I did the same thing.... I did find the answer in the manual!
Here's a copy of it (pg 23):
Set the command mode for the remote so it matches
the command mode for the recorder you set above.
1 Hold down ENTER
2 While holding down ENTER, enter the
command mode code number using the
number buttons.
Command Mode Code number
DVD1 number button 1
DVD2 number button 2
DVD3 number button 3
3 Hold down both the number buttons and
ENTER at the same time for more than 3
4 Let up, press RETURN, all done!
Jul 28, 2009 | Sony Televison & Video
Philips dvdr3430v dvdrecorder/vcr combo -hacked into to make multi regional 2yrs ago now buttons on machine not responding to touch only works with the remote, therefore cannot open disc tray. please help
Keep pushing the "STOP" button on the Remote-controller will open the tray. This works mostly on all Philips DVD's. I tried on my recorder, it works.
Have fun!
Mar 07, 2009 | Philips DVDR3430V DVD Recorder/VCR
Command mode change
Pretty easy, Recorder shows DVD1 in display..OK Slide COMMAND MODE Switch to DVD1 on remote Control. This switch is located in lowe part of remote control and has 3 settings.
Jan 04, 2009 | Sony RDR-VX521 DVD Recorder/VCR
Changing remote command mode for sony rdr-hx525 without remote control
Hold the "Enter" button along with the numeric button for the command mode you selected in Setup. This will reset the remote to work in the command mode you selected (also lets you get back into System Menu to try other command modes). If you pick a different command mode, you'll need to do this again to reset the remote to the selected mode. Found this info courtesy our friends on the Internet - no thanks to Sony's manual...
Aug 06, 2008 | Televison & Video
OK..I see the problem now.. Basically, you have to set both the remote and the recorder to the same command mode. (Default id DVD3). Please see the user manual I have posted in your premium query. It will tell you how to do this on page 22.
Jul 05, 2008 | Sony RDR-VX525 DVD Recorder/VCR
Blu-ray remote keeps triggering DVD recorder (and vice-versa)
You can "re-tune" your EX75 and its remote control by following the instructions on page 52 of the manual. This explains how to change the mode of the remote control. In short, you press the FUNCTIONS button on your remote control, get into the setup menu and select "others". The remote control entry is at the top of the list. You can change the setting from here.
May 22, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Dvd recorder rdr-hxd860
press stop button then the power button together the player will go off. put it on again the remote should work.
Mar 15, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Philips DVDR3320 DVD Recorder/VCR Logo
87 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
