This is probabaly your defrost system that is going out or it has already gone out!
I would start by replacing the defrost t-stat first. You have water leaking because your unit is frozen up and thawing out. The fresh food area is not coling because the ice is blocking your vent.
You can contact us at: http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
We http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
We will get the correct parts out to you right away and get your unit working properly again.
We are at your service from 7 AM until 9 PM CST Mon – Sat!
Thanks, Ella
Thanks, Ella
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged 5. defrost cycle not functioning properly if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional.
On the top back of the fridge is a unit that seems to be connected to the freezer. It leaks...
(More)
On the top back of the fridge is a unit that seems to be connected to the freezer. It leaks intermittently into the refrigerator and pools under the crisper baskets as well as wetting food that is on the shelves in its path.
the fridge is not as cold as it should be,and the freezer is not freezing,its a frost free fridge...
(More)
the fridge is not as cold as it should be,and the freezer is not freezing,its a frost free fridge freezer,the fan is still going,but not making the usual loud noises...help
ice maker leaks into ice bucket when filling tray. i found the water tube laying on the floor of the...
(More)
ice maker leaks into ice bucket when filling tray. i found the water tube laying on the floor of the freezer and just stuck it back in the filler hole. problem has always been water leaking into ice bucket and freezing into a solid mess.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
