Television switches off
I switch the television on but after a couple of minutes it just switches off i switch it back on with the remote but again it switches off after a while
  • 579 Answers
Give the make, model, and age please.
Posted on Jan 06, 2008
Hello, I have a Sony KDS-55A2000 and it works fine for a couple of minutes and then it switches off and the green led starts blinking for about a minute and then the picture comes back and works fine
First thought would be the lamp may be about to fail if it has not been replaced in a long time---a warning will be the picture is a bit darker than before and takes longer to get bright than it once did.
Apr 17, 2012 | Sony KDS55A2000 55" HDTV
I have switched the TV off at the switch. When I have turned it on again the picture doesnt appear and the red light just keeps flashing.
First you need to try turn it on using the remote, by pressing any of the number buttons on the remote. If it does the same, then you go ahead to press the power button from the television to see if it comes on.
If either of them does not turn on the television, then you will have to reset the television. To do so, unplug the television for some minutes, lets say about 5 minutes, then you plug it back on, then press and hold the power button for about 15-30 seconds and it will restart the television.
That should help start up the television.
Hope this helped.
Goodluck
Elect_Comp
Jun 27, 2011 | Panasonic Televison & Video
I have a CE32LD17-B, when the TV has been switched off from the remote control, sometimes it will not switch on agaian from the remote or from the TV. The only way to get the TV on again is to switch it...
Change the tv remote battery.Take some rubbing alchahol clean the remote sensor infer red LED light on the remote.Clean the tv sensor/remote board on the front of the tv with alchahol also.
Jun 11, 2011 | Sanyo Televison & Video
When i switch my tv on it turn's itself to standby, i can switch it back on again but it just keep's switching itself to stanby after a couple of minutes.
You need a live input source to the port that the TV is set to, or turn on the tv and switch input to a live input source, anything else and the tv shifts to standby.
Oct 13, 2010 | Televison & Video
My foxsat-hdr box will not switch on or off from the remote or the button on the front of the box. It is stuck in BOOT mode and can only be switched off at the back of the box. help
Do a power cycle. Unplug the box from the ac outlet and then wait a couple of minutes before plugging back in. If this doesnt work , contact your provider to have them reset over the phone or to ship out a new box
Aug 18, 2010 | Televison & Video
I have a Viewpia LC-32IE21H which does not want to switch on.
For a three years old set, first place to look is the main power supply capacitors, at least the 5vdc standby circuit is working, the problem can be as bad as the main controller board, but look at the power supply first.
http://en.wikipedia.org/wiki/Capacitor_plague
Nov 06, 2009 | Televison & Video
Red light flashes but TV wont turn on
If you dont have the led light on when plugged go ahead and replaced the powerboard, but if your led light is on when plugged then you will need to replace the mainboard.
Hope this info help you.
Jul 01, 2009 | Samsung LN32A330 32 in. LCD TV
TV keeps turning itself on and off, onto standby
I managed to find a local repair man who fixed the problem. He put in a new transformer.
Dec 01, 2008 | JVC AV-32D305 32" TV
We have a Hitachi C28W1TN, which is just under 10 years old that has recently started switching itself off. It goes onto standby by itself and when we switch it back on, it instantly does it again. At...
It's been a while since this post, but I may have had a similar problem with my Hitachi. With no reason it would switching on and off randomly. The problem was with a solder joint on main relay - it was cracked and would not keep the coil powered so i kept flickering on/off. This relay is located on the front of pcb, between high voltage area and the switch and on my tv it is blue. Check all four joints and apply some new solder onto them. Make sure the tv is not connected to mains ;-) Hope this helps
Oct 26, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
