Before you replace dryer element, how do you now it is bad and what tells you it is the element and not 3 or 4 other items that could stop the element from heating? If oyu tested the element directly (and this of course is nearly the only way to know if it is bad) then you obviously has access to it and should see what is involved in removing it. So, I believe you do not actually know if the element is bad. You need to search and test all the controlling items that allow the element to heat before condemning it. I believe you need a skilled service person. Goodluck, macgivor
Was this helpful?
Yes
No
Popular Solutions for Hotpoint Aquarius WD640 Front
aquarius wdl540 will not dry properly why? Still damp after 1 to 3 hours drying. Cannot find a...
(More)
aquarius wdl540 will not dry properly why? Still damp after 1 to 3 hours drying. Cannot find a filter, or mention of one in the manual.
I have Atlantic LF 454 TX. The door handle is broken with clothes still inside. I need to open it....
(More)
I have Atlantic LF 454 TX. The door handle is broken with clothes still inside. I need to open it. Please help me.
hi my wd 640 comes up with fauilt F13 and leaks a little water which shows in front of the machine....
(More)
hi my wd 640 comes up with fauilt F13 and leaks a little water which shows in front of the machine. whats wrong? thanks for your reply chris
