PC gets shut down
I have observed that PC gets shut down when I installs any software.It is due to using CPU 100 percent.Because the message shows at the start when it is restarted.The message is says that the shut down was because of thermal effect.What shuld I do? Please guide me.
  • arunwadodkar Jan 06, 2008
    Please solve my problem.
  • 56 Answers
This means that it is overheating. you can do many things here. 1. take off the CPU cooler, and reapply some heatsync and see if that fixes the problem. 2. buy a larger, or more efficient CPU cooler, newegg.com is a great place to find good parts that are cheap and come with customer reviews already. 3. change the settings in your bios to allow the CPU to become warmer (do not go above 75 degrees) without shutdown or alarm.
Posted on Jan 06, 2008
6ya staff
SOURCE:
Laptop crashes several times a day then get message "caused Windows to shut down unexpectedly and restart". Microsoft Windows Error reporting states a serious problem and is "Stop Error or...
Hi and welcome to Fixya
Stop or blue screen error are caused by recent software installation or hardware modification. If you installed software recently, try to uninstall the software and observed the problem. If you modify something o the hardware. I recommend to revert the modification and observe the issue.
Let me know if you have questions.
Have a good one!
Feb 25, 2011 | Packard Bell Computers & Internet
Cpu shut down due to overheating
To Resolve this Problem . You have to go ta a computer peripheral shop and buy a Heat Sink Flux . Which help CPU to keep cool. Then apply this paste on processor Surface . Then again lock the fan and start your computer.
It Will Work Fine 100 percent Guaranteed
Aug 03, 2010 | Intel D945GCL Motherboard
My Gateway computer shuts down ramdomly. This
Listen for fans coming on, as this sounds like overheating issue. If fans kick in and then stay constant or dont work at all.
The link is for Notebook hardware control, this will monitor the temp among other things (only reference as a guide any software can give you an indication but not exact temp) Generally if a laptop hits 90c it will auto cutout to stop major hardware failure normal running temp (40-55c upwards depending on use) http://www.pbus-167.com/
If the machine is overheating it could be due to blocked vents, faulty heatsink, fans not working or incorrect fitting and thermal paste.
In all honesty if this is due to overheat problems, as the machine has been cutting out my strong advice would be to do all the above ESPECIALLY re-apply thermal paste (arctic silver5) to cpu, it takes about 100-200 hours of use to start to work 100%.
hope this helps, let me know if i can be of further help
Nov 06, 2009 | Gateway T1623BU 14.1" Notebook PC PC...
My computer shut down automatically when i run a video on internt
1. video GPU overheat
2. cpu overheat
3. virus
Check all of these things rule them out 1 by 1 there is no true way for me to 100 percent point out the issue without seeing your computer personally. May I suggest a hat session with us? We can figure out and repair 1000's of issues via chat try it.. This answer is 100 percent free please do rate the best thanks.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Sep 23, 2009 | IBM NetVista A40 PC Desktop
2 ghz processor running at 220 mhz
Have you tried right clicking on the desktop (opening Display Properties), clicking on Screen Saver tab, Clicking the Power button, and setting the power schemes to Home/Office Desk? If its set on laptop it will reduce the processor speed when running on battery. I have noticed that even with it plugged in that some times it will run at half processor speed. Try that out.
Have a great day,
Armymason
Mar 02, 2009 | Dell Inspiron 9300 PC Notebook
100 percent and then nothing
1. Try do download latest version.
2. take you memory stick, go to your frined get the installation file on that and the install it from memory stick on your pc.
3. contact yahoo technical support.
http://help.yahoo.com/l/us/yahoo/messenger/contactus/contactus-01.html
Feb 25, 2009 | Yahoo Messenger
Startup Problems with Lenova T61 Thinkpad
Start by unplugging the non-essential devices one at a time and rebooting.... after you have found which device is causing you problems... use the install program for the device then shut down... add the device and see how it goes.
Robert
Dec 22, 2008 | Lenovo ThinkPad T61 Notebook
Pc shutdowns after frequenly in some work
at what time after the booting is it shuting down, check the cpu fan , some times system shut down due to overheating, if its ok, then also check some other RAM.
Nov 03, 2008 | Microsoft Windows XP Professional for PC
New CPU installed Message
It will probably be your cmos battery that is flat and losing the saved settings, this can be located on the motherboard, it is a flat disc shape (CR2032)
Apr 10, 2007 | ASUS P5LD2-VM Motherboard
55 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
