Kenmore 44102 Front Load Washer
Problem for Kenmore 44102 Front Load Washer
My kenmore washer fills with water but will not
By jfarmer187 on Nov 09, 2009
My kenmore washer fills with water but will not drain or spin
Best Solution
posted on Nov 09, 2009
Helpful)
jsrock516
Rank: Guru  Kenmore Washers & Dryers  Expert
Rating: 96%, 7227 votes
Check your lid switch. If the washer fills and agitates, but stops at the rinse cycle, or, if the washer fills, then stops and will NOT drain, this is a common symptom of a lid switch malfunction. The following link explains how to access and/or replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30. Prices differ between these sites, so shop around for the best price.
This is a very simple repair, but if you have questions, please let me know. I hope this helps you.
NOTE: You do not need to drain the washer to replace the switch.
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Kenmore 44102 Front Load
Questions and Unsolved Problems for Kenmore 44102 Front Load
Do you recommend Kenmore 44102 Front Load Washer?
Answer
Answer
quits working in the first wash cycle . Have to either unplug and restart several times to get to... (More)
Answer
how to put the spring around the rubber to hold it against the drum. it poped out
Answer
My Kenmore front loading washing machine has had previous problems with not draining properly. Now... (More)
Answer
washer will not go into high speed spin to remove the water. checked the belt and motor.
Answer
washer doesn't final spin clothes are soaked when done
Describe your Washing Machines problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in , GA
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
