Toshiba 32A33 32" TV
Problem for Toshiba 32A33 32" TV
Whent he tv is on, we see a thin horizonal line.
By annetteferri on Nov 09, 2009
whent he tv is on, we see a thin horizonal line. the sound is good...you can hear what's going on, just a black screen with thin horizontal line. TV is only 2 years old. Toshiba TheatreView SD
Best Solution
posted on Nov 09, 2009
Helpful)
tonygill
Rank: Guru
Rating: 95%, 72 votes
HELLO
I wish I had a £1 for every time I answered this! This is field collapse where the probable cause is the Field Output IC itself, or dry solder joints on the board where the IC is soldered in.
If you are not familiar with electronics then I urge you contact a service centre in your area.
ALL THE BEST (:-)
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Nov 11, 2009
Very Helpful)
Abrsvcs
Rank: Guru  Toshiba Televisions & Videos  Expert
Rating: 88%, 1825 votes
THe problem is either poor solder connections at the vertical IC (LA7833) or a defective IC. This IC should be attached to a heatsink and will be small and flat with about 9-11 Pins. The marking LA7833 will be on it as well. If you can solder, resolder the pins first. If that fails to resolve the problem, replace the IC (rough cost $15-$20). Please note that it is possible to have defective capacitors in the circuit as well. Once the IC has been replaced, try the set and describe the picture if it is not corrEct and we can guide you to the remaining defective parts (if there are any).
Dan
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
Not Rated)
tlm931
Rank: Guru  Televisions & Videos  Expert
Rating: 89%, 55 votes
you are having problems in the verticale circuit it can be the verticale ic and associated components
you will probably want to contact a servicer to assist you with this repair
Was this helpful?
Yes
No
Popular Solutions for Toshiba 32A33 32" TV
Questions and Unsolved Problems for Toshiba 32A33 32" TV
Do you recommend Toshiba 32A33 32" TV?
Answer
Answer
i need the code for my toshiba tv to use the satellite remote control instead of the remote that... (More)
Answer
my tv has red stand by light on and green flashin light..no picture
Answer
my Toshiba 32 inch tv, the menu options keep flashing across the bottom of the sreen and wont stop.... (More)
Answer
My remote doesn't work but the batteries are fine. Also the volume and channel button on the tv... (More)
Answer
Our tv hums everytume you turn it on...no picture or sound...is it fried???
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba 32A33 32" TV:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
