Question about Mitsubishi CS-35405 TV
Vertical lines I have uncontrollable verticals lines on my mitsubishi tv. At first, they would go away after the tv was on for several minutes. It started to take longer and longer for them to go away. Now, they don't go away at all. What can I do>
  • 579 Answers
The display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Hope ya fix it!
Posted on Jan 06, 2008
Vertical lines on tv
Your video driver or power supple board are going out.
Nov 17, 2013 | Mitsubishi WD-60737 60 in. HDTV
Mitsubishi 40" TV, LT-40134 Vertical lines on left side of screen
I've got the same TV with the same problem. Sometimes by moving it on the stand the lines will go away but it only sometimes temporarily fixes the problem. For a while it seemed like it needed to heat up to go away but that is not the case. It seems like there is a bad connection somewhere but i cant seem to find it. One day, one thing will fix it, then the next day it wont do the trick. It gets very irritating.
Oct 09, 2009 | Mitsubishi LT-40133 40 in. LCD HDTV
LCD TV vertical line
If the line is vertical and "One Pixel Wide" (Pinstripe) then the LCD Panel is bad and needs to be replaced. Contact 1-800-SAMSUNG to set up service.
Jul 14, 2009 | Televison & Video
Sony KF50WE610 Vertical Blue Lines Across Screen
the vertical blue lines indicate some interference from other electronic gadgets near your tv. it started showing up on my sony grand wega when i installed my wireless modem. i almost ordered a new rear projection lamp costing over $100 but decided to experiment. i first moved my desk computer farther away from the tv then isolated the wireless modem router by placing it inside a small glass - the vertical blue lines became lighter in color so i dedided to find another small glass that fit inside the first glass container then put the router in the double glass - no more blue lines and my wireless modem router still works.
do some deductive thinking to figure out what's messing up your tv and isolate the interference.
good luck!
Jan 18, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
White dots/green lines
The problem could be in vertical blanking or video processor circuit. Also redish vertical lines may be from external RF or magnetic interference. Move set to new location away from appliances and speakers
Apr 21, 2008 | Sony KP-53V85 53" Rear Projection...
Toshiba 46In HD Rear projection TV Vertical lines on screen
We also have vertical lines with our JVC 62"... turning it off and letting it cool down is the only solution. For us, we know it's a problem with heat. We simply are wits end on fixing it. added two additional fans, a exterior fan to blow heat away from the back of the tv, pulled everything else away, etc.... Anyway, goodluck.
Dec 24, 2007 | Toshiba 46H83 46" Rear Projection...
Tv vertical lines
Remove back .... lightly tap modules with plastic screwdriver
handle to isolate where bad connection is.....pull module or
chassis...solder,then repeat until problem solved......T.
Dec 24, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishis TV Problem
have a Mitsubishi TV 1993. Model CS-35301. The problem is that there is a white line that is running through a blank screen. The sound is fine just no picture. Have you heard of "Vertical Collapse?" I would love to save the TV. Hi nothing to worry just minimise brightness to avoid screen burn. "Vertical Collapse?" means one bright hor.line in the middle of screen. this problem can be solved 1 check vertical yoke connector or wire loose 2 check supply to vertical section which normally comes from EHT transformer check components in vertical section or print loose regards thanks
Sep 10, 2007 | Televison & Video
Televison & Video Logo
53 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
