Question about Samsung DVD-HD841 DVD Player
Tray will not open
The batteries are good. Tray will not open with remote or on the player.
    Scholar:
  • 47 Answers
Hi yok-83,
Can you hear the drive straining when you press open on the front of the player? If you can then it's jammed and you need a service engineer to open it and rectify the mechanism fault. It's most likely just the lubricant has dried up and gummed up the works. It's common problem easily fixed. If you don't hear anything when you press the button then it's a more serious fault and it's most likely less expensive to just buy a new one than have it repaired.
Regards,
Spare head 2.
Posted on Jan 06, 2008
DVD home cinema DH4430P. How can I make it region-free?
Open tray and remove any disks in tray, then Close the tray.
1. Switch Off Player and Unplug from mains wait 30 seconds (this clears RAM)
2. Reconnect to mains
3. Turn on player with remote.
4. Press ENTER on remote.
5. Press 8, 4, 2, 6, 9. Using keys on remote.if your player is already set to region 26. Press ENTER on remote. (The tray will open and player will power off and close tray.)
7. Switch on power from remote.
8. Player is now Region Free.
Mar 14, 2016 | LG Televison & Video
My JVC DR-M70 dvd recorder tray won't close.
Sorry for the delay in following up. My tray problem appears to be resolved, but I wanted to wait a few days to see if the problem returned.
After reading several suggestions on various sites for other makes and models, I started experimenting to see if any would work on my machine. I made several failed attempts before hitting on the right sequence of steps. To the best of my memory, THIS is what finally worked for me:
1) I gently pushed the tray back to it's closed position (note: the solution did not work during previous attempts when I left the tray open)
2) I unplugged the machine for 30 seconds,
3) holding down the remote's open/close button, I plugged the machine back in and immediately pressed the stop button on the player, holding both buttons down for 30 seconds.
4) I unplugged the player AGAIN for 30 seconds, then plugged it back in.
A MIRACLE! Upon hitting the open/close button on the remote, this time the tray opened exactly as it should, and it's been behaving itself ever since. I don't know if any of the steps I performed were unneccesary. All I can tell you is that every time I left out a step, it failed. The first time I followed every step, I had success.
As for my remote: I put in fresh batteries. The open/close button still occasionally tells the tray to open and close simultaneously. tvdokter has suggested cleaning it on the inside, but unfortunately, I only see one screw (inside the battery compartment.) I can't see how to get in without breaking it. Oh well, at least I'm back to be able to play and record my dvds.
Anyway, thanks for the advice. I hope this solution will be helpful to someone else down the line. If anyone has any questions or comments, feel free.
Aug 27, 2009 | Televison & Video
Want to play my old DVDs from overseas, but I get a region code error.
Try the following:
1. Open tray and remove any disks in tray.
2. Close tray.
3. Switch Off Player and Unplug from mains wait 30 seconds (this clears RAM)
4. Reconnect to mains
5. Turn on player with remote.
7. Press 8, 4, 2, 6, 9. Using keys on remote. If your player is already set to region 2
8. Press ENTER on remote. (The tray will open and player will power off and close tray.)
9. Switch on power from remote.
Apr 16, 2009 | Samsung HT-DS610 System
Region free code for samsung HD-BD2E
Haven't tried it, but found this online somewhere....
2. Close tray.
7. Press ENTER on remote. (The tray will open)
8. Switch off power from remote, then switch back on.
9. Player is now Region Free.
Jan 22, 2009 | Samsung BD-UP5000 Blu-ray and HD-DVD...
Battery into wireless remote?
Turn the remote upside down, so the back side is facing you. Where the lines are on the bottom, take your thumb & move it in towards the right & pull towards you to open. Place the battery in the tray (you'll see it fits right in the slot) with the words on the battery facing up. Slide the tray back into the remote.
Hope this helps :)
Jan 02, 2009 | Altec Lansing Inmotion-IM600...
Remote Control Altec Lansing IM600 - Battery
Turn the remote upside down. At the bottom, there is a slot that opens the battery tray and a series of grooves that are part of a clip that releases the tray. Insert the fingernail of your thumb into the grooves and the fingernail of your index finger into the slot. Ease the grooves (clip) toward the middle of the remote and slide the tray out. There is a ridge in the tray that matches the battery only when the battery is in the proper position. Slide the tray back in. If the remote doesn't work, you've probably inserted the battery in the wrong position.
Dec 31, 2008 | Altec Lansing Inmotion-IM600...
Need code to unlock international dvd's on a samsung htbd2t blu-ray dvd player
hope this helps
2. Close tray.
Nov 23, 2008 | Televison & Video
I need to change region code for goodmans GDVD200CDGM
Region Code Hack: GOODMANS GDVD-200-CDG:
To convert this player to Multi-Region
1. Open the disc tray.
2. Place a region 1 disc in the tray, but don't close it.
3. Press the buttons 0, 1, 2 and then 3 on your remote control in order, one at a time.
4. Press the play button on either your remote or the player.
To return this player back to Region 2 only and its factory default settings
2. Press the Zoom button on your remote control.
3. Press the Retu To return this player to Region 2 only (alternative method) rn button on your remote control.
4. Your player should now go into Standby mode.
5. Press the Power button on your remote control.
i). Open the disc tray
ii). Place a region 2 disc in the tray, but don't close it
iii). Press the buttons Return and then Play on your remote control in order, one at a time
Aug 21, 2008 | Goodmans Televison & Video
Locked dvd tray.
with the unit off press and hold the stop button and the eject button.
Jul 08, 2008 | JVC TH-S11 Theater System
DVD Tray will not open
Uhm..
Unplug it/turn it on and off
Try to press the eject button and lightly pry the tray open with your fingers.
Call support.
Good luck
Dec 21, 2007 | Jwin JD-VD130 DVD Player
Samsung DVD-HD841 DVD Player Logo
185 people viewed this question
Jerry Greenberg
Jerry Greenberg
