Heaters
Problem for Heaters
Generic problem for all Heaters
I recently purchased Honeywell programmable
By Hunter242 on Nov 09, 2009
I recently purchased Honeywell programmable thermostats to replace Rodgers-White mercury thermostats. I somewhat understand the universal color codes for heating/cooling (R,G,W, Y, R (Rc,Rh) and C) but of course mine has to be different. I have a 2 wire system (no A/C) gas fired boiler, hot water baseboard. The baseplate on the mercury thermostat has the red wire connected to R (also labeled ''5'') and the white wire connected to a terminal labeled only with ''4''. The G, W, Y and C termials are not used. For a 24 volt 2 wire system shouldn't it be R to R (supply 24-volt power) and then to W for heat? What do I connect the ''4'' wire to on the new Honeywell? I assume the ''W''?? Help.
Solution #1
posted on Nov 10, 2009
Not Rated)
ASK HANK
Rank: Wiz  Air Conditioners  Expert
Rating: 84%, 139 votes
yep- 1 wire to R the othe to W (or W1) dosent mater which is which
Was this helpful?
Yes
No
Popular Solutions for Heaters
Questions and Unsolved Problems for Heaters
Answer
goodman furnases reliability
Answer
best heater for a 5,000 square foot monolithic dome
Answer
Unit does not provide any heat. Is there a service agent in Glasgow area i can contact ? Jim Boslem... (More)
Answer
part for a r60 reddy kerosene heater
Answer
I can get it to light holding yellow button in for 30 seconds, but as soon as I release it flame... (More)
Describe your Heaters problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Heater Experts
Top Heater Repairmen
in , AK
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
