Question about Samsung SF-340 Plain Paper Inkjet Fax
Dialling out! Hi! We have a Samsung SF-341P phone/fax machine. We are able to receive calls but are unable to dial out. As soon as we enter the fourth digit, the busy tone sounds and no call can be made. Any ideas why?
  • 417 Answers
Hi make sure that you don't need a prefix number i.e. a 9 to dial a outside line. The best test is to plug a normal phone into the socket and call someone from that line. If the same problem is still there then it is a line problem if not check within the machine menu that under TTI or call settings that there is no prefix number installed. If there is set the machine so it doesn't need a prefix.
I hope this helps you
Thanks J
Posted on Jan 08, 2008
Fax to 1-815-346-2473 on my SF 650 machine?
Dear
first check the no 1-815-346-2473 with your telephone company. In the said model there is a handset. do -lift hand set here the companys dial tone dial the required tel. no. here the Rx.tone from the other fax machine connected. If its working definitely your fax machine will transmit the data.
If the fax machine has connected behind EPABX, it has unique no. to dial out side of the epabx. In that case contact your EPABX provider to program the fax machine.
Thanks.
Dec 18, 2014 | Samsung SF-650 Laser Fax Machine
Not receiving any incoming faxes
Is the phone line working? Do you have any devices connected to the phone line that pick up before the fax machine? Make sure the machine has paper and is set to FAX or AUTO. Is there a Memory Full error? Clear the memory (Setup > Memory Clear then press Start/Enter. Use the left and right arrows to select the items to remove. Press Start/Enter twice (second time to confirm the choice). Repeat until all memory is cleared that you wish to clear. Then press Stop to exit.)
If you are using the ANS/FAX mode and have an answering machine connected to the extension port, disconnect the anwering machine and switch to FAX or AUTO. Check if the machine receives faxes. Sometimes the extra device causes interference. Call the fax machine from a different phone number and see if you hear the fax tones.
Check that the Junk Fax barrier is off, if the incoming call is from a machine that is not listed in your speed dial database. If you have a distinctive ring, make sure that the Fax machine has learned the ring by pressing Setup go to DRPD. Choose Set and call the fax machine from another phone. The LCD will say Waiting Ring until it gets that call and then once the ring is learned will say END DRPD Setup
I hope these ideas help.
(If you have a phone company voice mail service, the faxes may end up stuck in that box. It depends on how many rings the fax is set to wait before picking up versus when the voice mail opens to take the call.)
Jul 16, 2010 | Samsung SF-515 Plain Paper Laser Fax
Unable to send/recieve with my Samsung SF 565P fax
Plug a phone in to fax port, Is there a dial tone there also? can you dial a number and make a call from the fax port? You should be able to with a regular phone. If you can't, try plugging in the fax machine to the other port where your phone is plugged in. try sending a fax.If it works there, then the Vonage device or your service itself is the problem.
Apr 22, 2009 | Samsung SF-565P All-In-One Laser Printer
SF 2800/SF800 with Digital Answering System is locked or blocked
I still have not been able to solve the problem.
I feel that this machine is totally out of date
Jan 21, 2009 | Brother IntelliFax-2820 Laser Fax
SF-341P
Remove all papers from the machine, unplug it from the mains suply and try all over again,
If the problem persist most probably there is a broken or an unplug actuator sensor inside the machine or in the scaner area.
GOOD LUCK.
Oct 31, 2008 | Samsung SF-340 Plain Paper Inkjet Fax
Hpofficejet: will not receive fax. Sender is given our phone number, our phone is answered and we dial our code -- this no longer works. Cannot find manual. Do we reset the number and how, or what...
I just got a new line just for my SF-5100 fax. It was working before I switched to this phone company. I checked the line on a regular phone and it seemed ok. When I plug it up to my fax machine, when it rings I get this static sound instead of rings. One of my customers said when she tried to fax something, she got that same static sound and it would not go through. When I tried to fax her something, I dialed the number and when the fax machine was repeating the numbers it was a series of that same static sound. Then the operator said I should try my call again - so it did not dial through. A few minutes ago, the screen said RX also. Can you please help?
Oct 07, 2008 | Samsung SF 5100 Laser Printer
Sf-5100 issue
Kindly check the setup. Before anything refer to manual and check that you are getting a dial tone for sending in a telephone set.
Best Regards
Rafique
Mar 27, 2008 | Samsung SF-5100 Plain Paper Laser Fax
Can't get the machine out of "broadcasting mode"
have you tried to see if paper is jammed in side of the fax manchine this will prevent it send/receving faxes .
follow your manual instructions for this .
you could also contact samsung on the number 08707267864 8am-8pm.
riz.
Nov 20, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Unreceivable
Manual can be found here: http://www.samsung.com/support/productsupport/download/FileView.aspx?cttfileid=526982&type=Multi+Function+Printer&typecode=16&subtype=Laser+MFP&subtypecode=&cmssubtypecode=1601&model=SF-5100I&filetype=UM&language= Does the unit ring at all? If it does do the following (taken from the manual) Receiving automatically in FAX mode 1. Press Rcv.Mode/Contrast until the display shows ?FAX MODE?. 2. When you get a call, the machine answers the call on a specified number of rings and receives a fax automatically. You can change the number of rings. See ?RINGS TO ANSWER? on page 5.4. To adjust the ringer volume, see ?Adjusting volume? on page 2.8. If the phone is not ringing, then the call is never even getting to your fax machine. Hope this helps If you need more information, please ask before rating this solution. Ed
Jun 09, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Samsung SF-340 Plain Paper Inkjet Fax Logo
139 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
