Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Problem for Bissell 1699 ProHeat Clear View Upright Steam Vacuum
I have a bissell proheat turbo2x the brushes wont
By taylorneil8 on Nov 09, 2009
i have a bissell proheat turbo2x the brushes wont rotate checked for blockages none to be found can anyone help
Solution #1
posted on Nov 09, 2009
Not Rated)
Vac Belts
Rank: Wiz  Vacuums  Expert
Rating: 80%, 63 votes
The belts are probably broken, stretched or worn. I would try replacing the belts if you haven't in a while. You can get the belts you need here:
Bissell 1699 Replacement Belts
Was this helpful?
Yes
No
Popular Solutions for Bissell 1699 ProHeat Clear
Questions and Unsolved Problems for Bissell 1699 ProHeat Clear
Do you recommend Bissell 1699 ProHeat Clear View Upright Steam Vacuum?
Answer
Answer
My Bissell proheat shampooer releases the shampoo on the carpet but when I go to ****-up the dirty... (More)
Answer
I have a Bissell Prohet Clearview Plus. The foot pedal is broken and accessory holder is broken. Can... (More)
Answer
Bissell Pro Heat clear view plus...Flow indicator not turning...? Plugged? how to unplug
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bissell 1699 ProHeat Clear...:
Top Vacuum Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Vacuum Experts
Top Vacuum Repair
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
