Monitor is not clear and no sound (win 98) pentium 2 board
After the installation of win 98, the monitor (vga) graphic was not clear, i try to set it to 256 color, but the setting did not work, and also the sound did not work, the media player is not showing well due to the monitor problem.
all the cards are on board. windows complain of not getting compatible driver for the monitor and sound
INSTAL WINDOWS 98 PACK 3,BUT I DON"T HAVE SOUND
    Sergeant:
    Champion:
  • 243 Answers
You meed to go to the makers website and download the drivers for you graphics as they do not come with windows.
hope that helps
Posted on Jan 06, 2008
6ya staff
SOURCE:
Monitor says no video signal, not even from the onboard card. Do I need to get the DVI Graphics-SI card? I didn't get one with this refurbished board. I have tried PCI and PCI Express cards.
1) Monitor plugged into the VGA connector on the motherboard, (Rear Panel), you should get a display.
This is with the proper settings in BIOS.
Reset BIOS back to the factory default settings, and clear CMOS Error Codes.
Unplug the computer from power. (Monitor plugged into VGA connector on motherboard. No graphics card installed)
Press the Power On button in, and hold it in for a count of 5 seconds. (Count 1001, 1002, 1003, etc.)
Let go of the Power On button.
Do this procedure 2 more times.
Plug the computer back into power, wait 1 minute, turn the computer on.
If you get OnBoard graphics now is the time to install the drivers for the graphics card.
Then close all windows, turn the computer off, unplug from power.
OBSERVE Anti-Static Precautions and physically install the graphics card.
Still no?
Time to enter BIOS Setup, and see what graphics settings you have.
(When the post screen comes up press the F2 key)
On the main page use the Right Arrow key to highlight - Advanced - at the top of the screen.
Press the Enter key.
Use the Down Arrow key to highlight - Chipset Configuration
Initiate Graphics Driver should have - PCIE - to the right of it.
This stands for PCI Express. This is the factory default setting.
Internal Graphics Mode Select should have - Auto - to the right of it.
With it set to Auto;
The OnBoard graphics will be automatically disabled when a graphics card is installed.
The OnBoard graphics will be enabled when a graphics card is Not installed.
This is the download page from AsRock Support, for the User Manual for the AsRock ConRoe 945G DVI motherboard,
http://www.asrock.com/mb/manual.asp?Model=ConRoe945G-DVI
On this page click on Click Here to the right of User Manual, after you have chosen what country that is nearest yours.
Allow time for the PDF file to download. (Sometimes up to 30 seconds, and additional time may be needed to fully download the file)
I would also like to know what Power Supply you're using, and if you are sure beyond a doubt that it is a Good unit.
Regards,
joecoolvette
Jun 05, 2011 | Asrock ConRoe945G-DVI Motherboard
I m using Intel D945GNT board, from last 2 weeks i m installed the win 7 on it and add the (ATi x300 ,128Mb,Pci Express) graphics card, but the LCD showing lines behinde.when i m using builtin board...
so this is a custom PC, yes, be nice to lead off with that fact first no?
so the driver for the ATI card is wrong
go to ATI and get the correct driver
dont expect W7 to magcially get any video driver right.
that is your job as custom builder.
(it can only be 2 things, it seems.
bad card
or its driver bad.
I assume you use BIOS to switch from the 2 , correctly)???
May 27, 2017 | Compaq TFT8020 18.1" LCD Monitor
Hello! I have a processor intel pentium dual cpu e2160 @1.80 Ghz and for display a graphic card NVidia GeForce 7300SE/7200 GS, DAC Type Integrated RAMDAC 512 mb. I use my VGA monitor connected to the video...
No it can not be possible you can use multiple cable two way .it can solve your problem.Some mother board or laptop has duel option. In that devic can any body use two moniter.
Nov 24, 2010 | Intel Computers & Internet
Hi, Monitor is acer x193hql 18". Have just reformatted my HDD and installed XP (Was XP previously) Resolution now seems to be stuck at 800x600. Have tried Control...
So you say you formatted hey? This seems to be a problem with the GPU (Graphics Processing Unit) and not the monitor itself. Try re-installig and VGA drivers for your graphics card, if you are using on-board graphics, then install the VGA drivers that came with the motherboard.
Nov 15, 2010 | Acer AL1916W 19" LCD Monitor
Integrated Visual (VGA).. Not sending signal
One never knows what settings the manufacture set the board to. So clear your bios. See the page 1-16 in your manual. Doing this should reset the bios to default settings. The onboard VGA graphics controller should send video to your monitor. If you still don't receive display the problem is with the bios or the graphics controller. Your board is no longer warranted. However you can buy an updated bios chip from Asus. Call 812-282-2787 M-F 8:00AM-5:00PM. Have your serial number ready. You'll find that number on a sticker over the LPT port. I already went to Asus online estore to see if they had a new bios but no such luck;
http://estore.asus.com/shop/category.asp?catid=137
Mike
Oct 15, 2009 | ASUS A8N-VM Motherboard
Adding a video card and get no output
Look in the motherboards manual for info about installing graphics cards, see if it needs jumpers. Plus make sure you plugged the monitors vga or dvi on the right place (VGA or DVI port ON the graphics card, NOT on the old vga port you used to plug your monitor before )
See if it works otherwise tell me..
Sep 14, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
WINDOWS 98
You probably don't want to hear this but I really do not recommend that you do this.
The reason has to do with your hardware.
System Requirements for Windows 98:
486DX 66 megahertz (MHz) or faster processor (Pentium CPU recommended)
16 megabytes (MB) of memory (24 MB recommended).
A full install of Windows 98 on a FAT32 drive requires up to 255MB of hard drive space
VGA Graphics
The minimum hardware requirements for Windows XP Home Edition are:
Pentium 233-megahertz (MHz) processor or faster (300 MHz is recommended)
At least 64 megabytes (MB) of RAM (128 MB is recommended)
At least 1.5 gigabytes (GB) of available space on the hard disk
Super VGA Graphics
To be honest the posted minimum requirements for XP have long been considered a joke. A system twice as powerful as they recommend will probably still run slower than your current system with 98.
I am of course assuming that Windows 98 was originally installed on your system and it has circa 1998 hardware.
Sep 29, 2008 | Microsoft Windows 98 for PC
TFT screen not working
hi
clean your vga ,fix it in your agp slot also remove dust from it .
reconnect all cable to board.also clen processor case.
clear your bios.
take away cmos cell for 15 minutes.
Mar 24, 2008 | MSI FX5200-T128 (128 MB) Graphic Card
Your problems sounds like you are missing the drivers, can you provide the model number of your motherboard.
or you can go to
http://www.intel.com/support/motherboards/desktop/
and download the correct drivers for your motherboard
Dec 27, 2007 | Intel Motherboard
Open Questions:
Computers & Internet Logo
61 people viewed this question
Ekse
Marvin
Marvin
