Question about Yamaha RX-V2700 Receiver
The subwoofer preout is not working
I just got the RX-V2700 and hooked it up. I can't find a way to make the subwoofer preout work. Through GUI I set everthing up but still none of the preouts are working. I'm lost. Please Help!
  • 1 more comment
  • Yodelenfritz Jan 07, 2008
    The subwoofer has 2 input RCA Jacks and 2 output RCA jacks and 4 speaker wire connections for inputs and outputs its a Velodyne Sub.
  • Yodelenfritz Jan 08, 2008
    Ok. Thanks. But why can't I use the Subwoofer preouts?
    I have a single Pre-out for the subwoofer but 2 inputs for left and right on the Sub. I didn't try to split it. I will have to go to best buy or one of these places to see if they have the monster cable you are talking about. I will stop tomorrow.
    Thanks for your help.
Learn to write english godamnit
Posted on May 01, 2008
  • 1,067 Answers
Does sub woffer have speaker wire in and outs run the fronst throw ther back up to front speakers pass throw it that would work
Posted on Jan 07, 2008
  • 3 more comments
  • nick helpap
    nick helpap Jan 08, 2008
    use speaker wires in from sterio then back up to front speakers from sub ok set reciver on full range for front dont limit them sub will do that set cross over at 120 hertz k
  • nick helpap
    well your sterio depends on how the sub outs are rigged up for to anther reciver or to sub wooofer do u have setting in sterio sub remix on off ? try those u said dint u subs on in reciver right sum have bad out puts happend to my buddies sub out worked 3 mo tnow it dont so we ran wire in and out to tops fromt f ch on sterio works great set cross over on sub at 100 120 depending on your fronts size whatthey can handle
  • nick helpap
    sun times the rca out of sterio is tricky is it a single sub out or left right subs out ?
  • nick helpap
    and sumtimes u cant use reg single rca cable to a spilter y cable to ins of sub did u try using mono only of sub right side with out y on it monster cables make speacial cable for this that go in and back out subwoofer cable do u own that cable u could try to use one of ther sub cables wired the right way may do it if not do wire way
  • nick helpap
    ok ya they make monster sub cable 10 13 18 ft depends how far u away they cost also 40 50 bucks but worth it desinged for sub that may do it for u if not take it back do speaker wires way ok
Yamaha RX-V1800 and Kenwood SW-505D Subwoofer No sound
I think you need to re-read the manual before attempting correct wiring.
Nov 27, 2017 | Audio Players & Recorders
How to connect yamaha rx-v2300 to wireless subwoofer
Your wireless sub should have some sort of transmit module. Hook that up to the subwoofer preout jack on the bad of the receiver.
Apr 19, 2013 | Yamaha RX-V2300 Receiver
I just bought a yamaha rx z1. i try to pluging to use the subwoofer is not working
If you have it hooked up to a TV via monitor out, it's easier to do. Press "menu" or "GUI menu" go to "manual setup" then "speaker settings" then "subwoofer" and select "both" If you need more help, post a comment and I can help you further.
Nov 18, 2009 | Car Audio & Video
Yamaha RX-V2700 no sound from any speaker outputs
Make sure that you have the correct input signal selected.
Also, check if the sound is not muted.
If you have a multi-room speaker switch, make sure it is set correctly to main speakers.
Apr 28, 2009 | Yamaha RX-V2700 Receiver
Hooking up a Logitech Z-2300 subwoofer to a Yamaha RX-V392 receiv
This is the exact same setup im lookng at, just a different Yamaha receiver (RX-V663). Since the 3.5mm headphone jack and and the sub preout are both 'line level' you just need to pick up a male RCA to female 3.5mm jack converter from radioshack. I'd expect it to be around $5-8.
I have already stripped my old 5.1 HTIB system rca connector to use the surround speakers with my receiver. They work but are cheap speakers. Im tempted to do something similar with the z-2300 speakers, much higher quality, but I would definitely use a converter instead of stripping to keep them backwards compatible.
Jan 10, 2009 | Logitech Z-2300 Computer Speakers
Pioneer DEH-P3000IB... Hook up RCA cables to 2, 2 channel amps for front and rear control. Supposed to be able to set rear to either rear full or sub... can't find how and all I'm getting is sub response.
Here are the directions according to the manual:
1 Use MULTI-CONTROL to select
2 Press MULTI-CONTROL to display the
setting mode.
# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment
you wish to set.
Press MULTI-CONTROL repeatedly to switch
the segment in the following order:
REAR SP (rear speaker setting)—PREOUT
(RCA output setting)
4 Use MULTI-CONTROL to select the desired
Turn to change the setting.
When REAR SP (rear speaker setting) is selected.
(full-range speaker)
When PREOUT (RCA output setting) is selected.
# When no subwoofer is connected to the rear
output, select REAR SP:FULL.
Hope this helps.
Oct 13, 2008 | Pioneer Audio Players & Recorders
Getting to work your pc music files through the usb connection
how should i connect my yamaha rx-v2700 to my desktop pc and which software i should install on my pc and where to download this software
Feb 12, 2008 | Yamaha RX-V2700 Receiver
Yamaha RX-V2700 skipping when playing a DVD on Toshiba D-R400
Sounds like a poor grounding issue between the units OR maybe they're not as compatible as the Mfg's say.
Could be a bad HDMI cable also. Most are made in the land of Nanking
Jan 18, 2008 | Yamaha RX-V2700 Receiver
My HDTV has no HDMI and I'm not getting a picture on the TV except for the Yamaha Backscreen
tell cable box 480 i putput not 720 p even tho big screen has hd inputs its not true hd ok unplug plug back in see if get cable box to defult u or take card in front in and out most likely tv cant handle 720 p or 1080 i if its on 1080 i bring to 720 still no pic tak ethe cable box out settings to 480 i ok try that 1st
Jan 06, 2008 | Yamaha RX-V2700 Receiver
Yamaha RX-V2700 Receiver Logo
937 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
