Home | PC Desktops | I bought the hp sli...
PC Desktops
Problem for PC Desktops
Generic problem for all PC Desktops
I bought the hp slimline s3707c a few mon...
By shamusmcgee2 on Nov 09, 2009
I bought the hp slimline s3707c a few months ago and I love it! But due to me being a huge gamer I needed to upgrade my Vid Card. The new card doesn't fit in the tower so I bought a bigger tower and was planning on just moving everything over to the new one but I'm having trouble disconnecting and disassembling everything because of how compact the tower is. Any suggestions on how to transfer the insides to a new tower without destroying them?
Best Solution
posted on Nov 09, 2009
Very Helpful)
junk4
Rank: Guru  Computer Hardware  Expert
Rating: 92%, 18 votes
My best suggestion is to get a professional installer to do it for you.
If you want to do it yourself.
  1. take the top of (make sure to ground yourself) and DONT work on carpet if possible. Static is bad!
  2. the HP is nice in the way that it has sliding internal features. So some of the chasis will slide out of the way. Take advantage of this.
  3. BEFORE you take ANYTHING APART make sure the mounting screws of the motherboard line up with the mounting area of your newly bought CASE. Also, make sure output on powersupply on new case comparable to your existing one, and that connector wll fit your MotherBoard.
  4. disconnect all power supply wires
  5. take out Power supply which will give you more room
  6. disconnect ribbon cables (or SATA), remove them.
  7. unscrew mounting screws on motherboard and put it in your new case. Make sure MotherBoard does NOT ground to your case (IE it should not wiggle around) and be put in securely
  8. remove peripherals from your old case and put in your new case (HDD, CDROM, etc.)
  9. connect power supply cables, then ribbon cables (or SATA if so)
  10. Put case together and connect wires in back (Monitor, keboard, etc.)
  11. Your are done, Congratulations!
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thanks Much! The advice helped a LOT!!! " - shamusmcgee2
Popular Solutions for PC Desktops
Questions and Unsolved Problems for PC Desktops
Answer
i have internet connection but its showing unidentified network. when i run diagnose then result... (More)
Answer
I do not want to buy any other product from you as I can not get the s peedupmyPC 2009 which I have... (More)
Answer
when laptop switched on dell logo appears then windows logo fails to appear and a blue screen with... (More)
Answer
i want to restore my advent 3312 pc to its original factory settings but i don't know how to do it
Answer
error 742 when trying to set up workplace vpn
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For PC Desktops:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
