Question about Toshiba 57H81 57" Rear Projection Television
Audio Problems TV has sound on all but 2 or 3 channels. Have tried to adjust the audio settings but when we go to 'Advanced Audio' and try to put the MTS to 'stereo' it isn't highlighted and won't let us select MTS to put it on stereo. Any ideas? We obviously can live with it but can't figure out what the problem is. Can this be a cable box problem or a TV problem? Also, one channel is broadcasting in Descriptive video (very annoying) and we can't get it turned off. Thanks.
  • joedana Jan 06, 2008
    I have a panasonic PT-51G30T rear projection.Turns off a second after I turn it on.The only way to get it to "try" to go on is unplug it and then plug in.Again shuts right off again.HELP!! It is built into a wall unit and hate to find a new t.v. that fits.
    Champion:
  • 206 Answers
First for the Toshiba could the SAP (Second Audio Progam) be turned on this will somtimes cause the audio to drop. And are you using the onboard tuner or does this set conect to a cable box?
Then for the Panasonic the most common problem for your fault would be the convergance curcuits are shorted and need replacment, or some other componet may be loading down the set and forcing it in to shut down, Tv's will do this to prevent further damage
Posted on Feb 13, 2008
Vizio tv problems
Have you checked the TV without other devices connected to the TV.
Eg. disconnect any home theatre or speakers from the TV.
Verify with audio menu if the settngs of TV speakers is on or off ?
To adjust the audio settings:
1. Press the menu button on the remote. The on-screen menu
is displayed.
2. Use the arrow buttons on the remote to highlight audio and press ok. The AUDIO menu is displayed.
3. Use the arrow buttons to highlight the setting you wish to adjust, then press left/right arrow buttons to change the setting:
• TV speakers - Turns the built-in speakers on or off.
Lastly have you tried restoring the TV to factory default settings.
To restore the TV to its factory default settings:
1. Press the menu button on the remote. The on-screen menu is
displayed.
2. Use the arrow buttons on the remote to highlight system
and press ok. The SYSTEM menu is displayed.
3. Highlight reset & admin and press ok. The RESET & ADMIN
menu is displayed.
4. Highlight reset TV to factory defaults and press ok.
5. If you have changed the default parental control passcode,
enter it now.
The TV displays, "Select Reset to restore all TV settings to
factory defaults and clear all account information."
6. Highlight reset and press ok.
7. Wait for the TV to turn off. The TV will turn back on shortly
afterward and the Setup App will begin
Apr 29, 2014 | Televison & Video
Low sound output from Front Speakers
The out put transisters are probally fried for the front channels,
Nov 27, 2012 | Sony STR-DE695 Digital Audio/Video Control...
My problem at my z5500 is that the light from the display is not working and also one channel is not working at all is the front left side channel.
im not sure i understand your problem??? however if you are having sound problems
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
Sep 17, 2011 | Logitech Z-5500 Computer Speakers
Channels for my z-5300 logitech not working
If you are having problems with you sound
also
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 21, 2011 | Logitech Z-5300 Computer Speakers
Can't change from MONO to AUTO mode
Hello
Can't make sound from mono to auto is your problem I thinks and posts this solution.
Hit the "Menu" button and surf through, come to "Sound Adjust" window.
The settings allow you to change and adjust sound in your TV. There are Bass, Treble and Balance control to adjust to your individual taste.
To adjust them
1. Press Menu button.
2. Press UP or DOWN button to select the desired item.
3. Press => or 4. Press EXIT button when finished.
When adjusting the parameter of "Balance" control, always set it to mid position to get stereo sound from both speakers. If it is set to any extreme end, there will be no output from the speaker of that side, and will hear as mono.
If you press "0" [Zero] button, you can reset the sound settings to it Factory settings.
To select 'Streo mode;
1. Press "Menu" button.
2. Press UP or DOWN button to select MTS [Multi-channel Telivision Sound].
3. Press => or [The ON AIR arrowtells you if a broadcast is in stereo AND/OR contains the SAP.
Press "Exit" button when finished.
Keep the TV in stereo mode to get the best sound quality. The sound will work in stereo
mode even if a certain broadcast is in mono sound only.
Choose the mono setting to reduce excessive noise on a certain channel or broadcast.
Selecting SAP will allow you to hear an alternative soundtrack, if one is available.
Apr 01, 2011 | JVC AV32F476 32" TV
Channel 2 (cbs) is fine. There is no sound. All other channels are fine. What is wrong and where can I take to have repaired. The TV is a 20" Norcent. I am in Summit,NJ, 07901
All the tv channels,work find and have sounds wright?Only channel 2 don't?Is not the tv,it channel 2 have broadcasting problems.U check around ur house the other tv channel 2 have sound?Tries go into the tv menu.Goto Audio Setting,go down to resetting the audio functions,now it going back to the factory setting,if it is the tv,that will help.
Nov 25, 2010 | Norcent Technologies TV2001 20 in. LCD...
Media player audio sund problem
Don't worry, small rodents haven't set up housekeeping in Windows Media Player. Instead, your sound card's clock most likely has a timing problem. To fix the problem, try reducing the hardware-acceleration level for your audio card by doing the following:
1.
In Control Panel, open Sounds and Audio Devices.
2.
On the Volume tab, in the Speaker settings area, click the Advanced button.
3.
In the Advanced Audio Properties dialog box, click the Performance tab, and then adjust the Hardware acceleration slider control to adjust the clock timing for your sound card.
Keep in mind that, if your sound card supports multichannel (5.1) audio playback, turning off hardware acceleration (by moving the slider to None) will cause the sound card to play all multichannel audio in stereo (two speaker) sound.
If you can't fix the problem by adjusting hardware acceleration, check for updates for your sound card by doing the following:
• Check for sound-card driver updates. You should scan for updates on the Windows Update Web site and also check for updates on the Web site of your sound card maker.
• Check for Microsoft DirectX updates by scanning for updates on the Windows Update Web site.
May 08, 2009 | Computers & Internet
TCL LCD TV. No sound on one channel only.
I had the same problem... try toggling through the "SAP" (multilingual audio feeds) for the channel. Mine was somehow set on "audio 3 of 3" for that channel, but there were only 2 audio feeds.
Feb 24, 2009 | RCA L37WD12 37 in. LCD HDTV
No Windows Media Player Audio from Surround channels
On WMP - go to Tools > Options > Devices > Select Speakers > click Properties > Audio Device to Use - ensure you select your audio Card (Not direct sound - just a precaution) > Advanced > Volume Tab > Speaker settings click on Advanced > Select the type of Speakers you have. - Hope this helps, let me know!
Oct 28, 2008 | Creative Labs Audigy 4 Sound Card
RCA 46 in rear projection
The first thing that I would check is in the audio menu to see if it is set on the SAP mode (secondary audio programming). If it is and there is no audio being broadcast on that channel, then you would have to turn SAP to off (which is usually what it is set to). Now there have been problems with the audio dropping out on regular CRT style RCA televisions where the audio would drop out, and you had to unplug the set for about 30 seconds to reset the TV, and I would try that next.
Dec 19, 2006 | RCA P46921 46" Rear Projection Television
Toshiba 57H81 57" Rear Projection Television Logo
101 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
