Question about KitchenAid KHWS01PMT Front Load Washer
Washer tub fills up after wash cycle is completed and machine shuts off
The tub fills up with water after the wash cycle is completed and the machine is actually off. what is causing this?
    President:
  • 878 Answers
Rich, your water valve is weeping, common and easy to fix. You will have to remove the 3 torx screws on the back of the top and slide the top off toward the rear. The valve sits on the left side in back. Couple clamps, couple screws and your done. Go to repairclinic.com and enter your model number and find the inlet valve. They will show you a picture of it with a price. Should be pretty inexpensive. Catriver.
Posted on Jan 06, 2008
Whirlpool utlra care II clothes washer shuts off when filling - push knob in and pull out it starts again - once full it completes remaings cycles
Hi, the water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Nov 17, 2010 | Whirlpool Washing Machines
Water leaks (drips ) into tub after cycle/spin is complete
You have a bad pressure switch or the small hose connecting to the pressure switch may be bad
If the washer leaks water when is filling only, check the following: 1.Fill hoses
2.The water mixing valve
3.Filling injector ( If your washer uses one )
4.Filling spout
If the washing machine leaks during the wash cycle, check the following:
1.The pump
2.The tub stem & seal
3.Tub to pump hose
4.The drain hose
5.Tub (rusted holes)
6.The drum support bolts
If the washing machine leaks during the spin cycle, check the following:
1.The drain hose
2.The tub cover seal
3.The pump
4.The pump hoses
5.The stem & seal
Feb 10, 2008 | Maytag LAT2300 Top Load Washer
Water continues to drip into the tub even after all cycles have completed. my tub is filling up with water, I have turned off the water to the machine but it continues.
The water inlet valve needs to be replaced. It's not shutting off the water completely. It's located where the water hoses connect to the washer.
Oct 09, 2010 | Maytag Washing Machines
My Maytag Neptune will not go into the spin cycle, instead the letters "nf " come on the display. What can I do to prevent this and to have the cycle completed?
Bonnie,
NF = No Fill the control board receives signaling for the washer during the water fill cycle. With most cycles the depth of water is around 3.5 inches in the wash basket. I know a Bulky Wash cycle selection will fill the wash tub to a high fill which is about 7.5 inches of water in the wash basket.
Is the washer filling the machine with any water? Do you hear water entering the machine? If you are doing a cold water fill and there is no or very little water in the wash basket with the NF error code. Try a Warm or Hot fill and see if the machine will fill and start the wash cycle.
Assuming you are doing cold water wash loads. You could have a water line block at the inlet screen or a failed cold water inlet valve which will not open. Try the above and let me know the results..........Rich
Sep 13, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Fill cycle stops before full
It's underfilling The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 03, 2010 | Kenmore Washing Machines
Washer over fills and water comes out the door. Water continues to run even durring the pump out cycle just before the spin cycle
  1. Water inlet valve. It may not be able to shut completely when the electricity to it has been turned off. The valve may leak and drip water into the clothes tub. Water may accumulate substantially and overflow. Remove the washer's cabinet to access it.
  2. Water level switch. This switch senses the water level in the clothes tub. It is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the air pressure in the tube increases and activates the switch when the water reaches a certain level. When the switch is obstructed, it cannot tell the water to shut off and the machine overflows.Clear it from any obstruction.
  3. Air-hose. It is connected to the water level switch through a tube. If the tube or hose is cracked or broken, no enough pressure builds up to trigger the switch and shut the water supply off. Check it for any obvious damage.
Oct 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune washer stop washing with 10 minutes left to go.
If your machine is a FAV6800AWW or FAV9800AWW the (upside down u and f) may be a “NF” for no fill error. The washer has tried to fill the machine with water and has sensed a water fill issue. The control board has shut the wash cycle down with an “NF” error to the display because of excess time to complete the water fill portion of the wash cycle.
Will the machine complete the cycle with Hot water only or Cold water only? I would do a Quick Wash cycle just to test with an empty wash basket.
Regardless of the above test and assuming you have good water pressure for both Hot and Cold supplies to the washer I would do the following. Close the water source valves to the washer and remove the Hot and Cold hose connections at the back of the machine and check for clogged inlet screens. If the water inlet screens are free of restrictions I would go into Service Mode and turn on the Hot and Cold water valves on one at a time and make sure the tub will fill with about 2 inches of water in about 3 minutes in service mode. Check both Hot and Cold inlet valves individually see page 16 of the SM Board Output Test, enter service mode and do the function test for both Hot and Cold Water Valve’s. If the inlet screens are clean and you have water fill restrictions in service mode we may need to look at replacing the water inlet valve assembly. You can turn on the drain pump in service mode to empty the tub or just start a wash cycle and the machine will empty the tub.
The Service Manual for reference. Sears Parts Direct for reference.
May 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Tub overflow
Remove the hose from the water level switch and blow air through it.
The water level switch air hose has a clog in it.
Feb 22, 2009 | Kenmore 24032\24036 Top Load Washer
Amana washer won't fill with water
1st I checked the power, compressor in garage had tripped the breaker to the washer circuit. This model has no bells or whistles to tell you if the power is on to the unit. Reset the breaker and unit works.
Thanks FixYa
Dec 22, 2008 | Whirlpool AWM5125/1 Front Load Washer
Washing machine fills in the water but does not start the wash cycle
The fact that it does not fill completely can be related to a problem with the water-level switch, that regulates the water level.
See from Repairclinic:
"This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch."
However, when it is only the switch the mashine usually completes the cycle, but with less water than normal.
A possibilty is that either the timer is faulty or there is a problem with the water supply.
Check that water is coming from water supply with regular pressure, and that hoses back there are not obstructed.
More likely you will have to replace the timer.
See again from Repairclinic:
"When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water."
  • You can find parts at the following websites, you need to input your model number. If the part is not listed contact them.
    Repairclinic
    Partselect
    Don't forget to rate the solution.
    Many thanks.
    Sep 01, 2008 | Washing Machines
    KitchenAid KHWS01PMT Front Load Washer Logo
    85 people viewed this question
    Top KitchenAid Washing Machines Experts
    gbob59
    Eric Taylor
    Pieter Vleeshouwers
    Pieter Vleeshouwers
    Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
