Washing Machines
Problem for LG Washing Machines
Generic problem for all LG Washing Machines
Replace LG washing machine seal
By david_cant on Nov 09, 2009
Something has taken a chunk out of washing machine seal. How easy is this to replace? There is a metal ring holding it in place and I am not sure how to remove this.
Best Solution
posted on Nov 09, 2009
Very Helpful)
ash0434
Rank: Guru  Washers & Dryers  Expert
Rating: 89%, 33 votes
Hi
When you open the machine door, you will see a manufacturer's badge. Record the model number and call around to order the door seal from your local parts vendors. Have the replacement seal ready when you are changing the seal. If you remove the seal and then go to source it, then you might not remember how it was put on initially.
To replace door seal, First turn off machine and unplug from its power source.
Next remove top lid. Two screws in the back of the top lid and you can slide the lid back and up to remove. See if you have a clear view of the door seal from above the machine and see how it is joined to the drum mouth. There would be a metal ring holding it in place. Locate the screw which tightens it and unscrew it to loosen the ring.
Next the wire ring which you have already seen on the front of the seal needs to be removed. These are normally spring loaded. Feel around the ring until you get to the spring tensioner. With a flat screw driver, stretch the spring to pull the ring out from around the seal.
Now observe how the door seal is clipped around the front panel of the machine. The seal has a groove which fits snug agains the rim of the front panel. You can now remove the seal by pulling around the edge.
Now go back to the top of the machine and do a similar thing to remove the seal from around the drum. Make sure you observe how it had fitted on originally, and also observe if there are any differences between the top and bottom of the seal where it sits on the door. There normally is a difference.
When replacing the seal in the reverse manner, make sure you fit the seal correctly around the lips of the drum and the front panel. make sure you also correctly tighten and refit the rings to hold the seal in place.
Once you have finished run a couple of quick cycles without cloths, to make sure there are no leaks and that the seal is fitted properly.
Good luck.
Ash
Comments:
Nov 09, 2009
- You welcome. All the best
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thanks you very much Ash, really clear advice. " - david_cant
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
Are there any new washing machines made that still have direct drive. That means that the agitator... (More)
Answer
Whirlpool Cabrio WTW6300 worth the $$?
Answer
loaded washer, poured in detergent, water was filling and I walked away went back an hr later and... (More)
Answer
Kenmore stackable 98702 washing machine will not run
Answer
clothes smell after being washed, seems like it is water that stays in the pump causing the clothes... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing... Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
