Question about Dell 2200MP Multimedia Projector
Dell 2200pm making noise
I have the Dell 2200mp projector, and it has started to make noise when running. It's a sort of squealing noise followed by buzzing - a louder buzz/hum than normal.
I think it has to do with the fan, but I can't figure out how to get inside and check it. All the screws holding it together don't seem to help me take it apart. Does anyone know where I can get instructions on how to take it apart? I don't have the warranty any longer.
Thanks
    Problem Solver:
  • 12 Answers
Most of the screws are accessible from the bottom of the case. Put the projector on its back and use a thin Phillips. There may be one other screw hidden on the side that has a plastic cover on it. Once you have loosened all the screws you can find, turn it over and try to lift the top part of the case. If there are still screws in place, you will be able to find them by seeing at which part the case does not wiggle as you try to lift it. That helps you find where the two halves are still attached and where the remaining screws are.
I have a 2200, but it is in the shop because it turns on and right off, and nobody could help me fix it. When I get it back, I might be able to help you find all the screw points.
Your fan has probably dried up and needs a drop or two of oil on the shaft where it goes into the motor.
An option if you cannot open the case is try to find the point where the shaft goes into the fan motor, and spray a little WD-40 at that spot using the red hose that comes with the can. If you get it at the right spot, the noise should lessen or go away completely.
Posted on Mar 24, 2008
I have a dell 2200mp the color wheel motor seems to be making noise, noise disapears when lamp is shut off can I purchase part or what is cost to have replaced?
Not experienced on dells ( I have only repaired sharp projectors) probably about AU$200-250 for the part and about $AU200 to get it fitted. It can be a tricky replacement particularly for the compact projectors
Good Luck
Jan 16, 2010 | Dell Office Equipment & Supplies
Dell 2200MP lamp turns off
Check to see if the fan is working, It maybe getting too hot.
Dec 28, 2007 | Dell 2200MP Multimedia Projector
Dell 2200MP makes a loud Humming Noise and vibrates
even if a fan spins it still can be noisy.clean all fans (i use a tooth brush).i also buy air in a can..(poundshop sells them).and spray them to clear any dust.when you have done that start the projector and see if is sorted...
Nov 02, 2017 | Dell 2200MP Multimedia Projector
Dell 2200MP Powers off
I have 2200MP projector that when you turn it on,it clicks about 8 to 10 times and then the power seams to turn on, but the lamp light light comes on and nothing lights up. it will shut down after that, with the green light still flashing. What could be the problem? Roger
Jul 28, 2008 | Dell 2200MP Multimedia Projector
Power Supply Unit of Dell 2200mp
first look at the dell site.
Then try to get your country dealer .
Before that contact your dealier
Jul 23, 2008 | Dell 2200MP Multimedia Projector
Dell 2200MP
Check that lamp cover microswitch closes (clicks). This microswitch disables the power supply when open. I had to bend the lever a bit to make it reliable.
Jul 21, 2008 | Dell 2200MP Multimedia Projector
Dell 2200mp mounting screw
Hi wspy
If the look right next to the holes there should be a screw size written on the casing itself.
Apr 29, 2008 | Dell 2200MP Multimedia Projector
Unit shuts itself down
Sounds like you have an overheating problem. Maybe a bad fan? Also you may have a bad connection to the "bulb".
Stargazer
Jan 14, 2008 | Dell 2200MP Multimedia Projector
Noise from color wheel
for any friends who is looking for optoma projector color wheel, DV10, HD20, HD70, HD70i, etc, please freely contact me, i'm a professional wholesaler and net retailer on projector spare parts, most of brand and all series, lens, color wheel, bulb and remote.
Jack
flying200809@gmail.com
Nov 16, 2007 | Dell 2200MP Multimedia Projector
Dell 2200MP projector
We have had two and they both did the same thing. We sent the first one back because it was still under warrenty, they sent us another one, it does the same thing.
Oct 29, 2007 | Dell 2200MP Multimedia Projector
Dell 2200MP Multimedia Projector Logo
166 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
