Check to see if there is a removable lower plastic cover at front of washer, if there is, then remove this, and you should find the pump filter located here, unscrew anticlockwise to remove and clean.
If no sign of filter, then remove rear panel of washer, and access the pump from here to check for blockage.
Please rate my solution.
Thanks.
bosch exxcel 1600 express. the conditioner section will not drain at the end of the cycle. at the...
(More)
BOSCH Exxcel 1600 Express. The conditioner section will not drain at the end of the cycle. At the end of the cycle I can press down on the blue guide in this section and the water will then drain away. We have taken the drawer out and given it a scrub with a stiff brush but this does not seem to stop the problem. Do not know how to get to any tubing to clean that as well if this is indeed the problem. Thank you
Have been using bosch exxcel for ages with no problems until today when a key appeared in digital...
(More)
Have been using bosch exxcel for ages with no problems until today when a key appeared in digital screen and wont let me do anything. I don't have instructions so can anyone help please!?
How do I fit a new door latch on my Bosch Classic Maxx 1200? Do I have to remove the door? I assume...
(More)
How do I fit a new door latch on my Bosch Classic Maxx 1200? Do I have to remove the door? I assume that I remove the back panel of the door? Help would be appreciated, no instructions came with the door latch. Many thanks.
I have a Bosch Exxcel 1400 Express washing machine. Have lost the manual. Can I get it to delay the...
(More)
I have a Bosch Exxcel 1400 Express washing machine. Have lost the manual. Can I get it to delay the finish - i.e. stop just before the final spin?
