Home | Air Conditioners | My panasonic cs-...
Air Conditioners
Problem for Air Conditioners
Generic problem for all Air Conditioners
My panasonic cs-2470kr split air con is lea...
By jmcc8322 on Nov 09, 2009
My panasonic cs-2470kr split air con is leaking condensate from the air unit. suspect drain blocked or tray broken. is it possible to remove the front cover to check it out. if so, how? Frank
Solution #1
posted on Nov 09, 2009
Not Rated)
drberry
Rank: Guru
Rating: 92%, 82 votes
Find the drain on the outside of the house (should be located near the condesing unit outside) it is pvc and as I said it should be near the outside unit. This pvc will be sticking out of the house to which you can take a wet/dry vac and hold it to the end of this pvc pipe and it should remove the algae that is clogging up your drain pan. This is the easiest way to unclog an a/c unit. Going to the inside of the furnance can be done using a wet/dry vac to remove the debris in the drain pan however, the clog could possibly be in the a/c condensate drain trap that is why I suggest going to the drain on the outside of the house and removing the clogg that direction.
Good luck on repairs.
Dave
Was this helpful?
Yes
No
Popular Solutions for Air Conditioners
Questions and Unsolved Problems for Air Conditioners
Answer
Looking to replace a 20 yr old Weil-McLain with a dependable, efficient oil-fired boiler for a... (More)
Answer
Our Quality: We believe that our customers should receive the highest quality Hp dv1000 battery at... (More)
Answer
Ruud furnace Model URKA A030jK08 Code opt 589 will sometimes ignite the fuel, and blow warm air as... (More)
Answer
remote will not turn on gas fireplace -- bateries have been changed
Answer
part number for remote control for air conditioner model bp6000er lg brand
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Air Conditioners:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
