Question about Garmin StreetPilot C330 GPS Receiver
Will not power on.
I push the reset with no luck.
  • 4 more comments
  • rivercare Jan 06, 2008
    I Checked the power cord, the leads and checked for broken connections/wires. I plugged in to the car power supply, tried the USB power connection and I took the face plate off and pressed the reset button. Still nothing happens. Now what?
  • Anonymous Jun 20, 2008
    My Garmin 330 StreetPilot will not power up via charger in the car. Thanks to the blogs at "FixYa", I connected to to my PC and Voila it works... Unfortunately, once I disconnect it from the computer it shuts down immediately. Do I assume battery issues?
  • tracyd99 Jun 21, 2008
    it was working fine and then it started to just come on by button and powers off by itself.
  • Anonymous Jun 22, 2008
    Will not power on. When I plug into computer I get a screen, but when I unplug from computer is once again goes off.
  • parshu477 Jun 22, 2008
    Mine is a little different. If not used for some time when I power it on, comes up for 3 secs approx & then powers off. Then even if I try to turn it on many times nothing happens.
    I looked @ Garmin's on line very small manual & followed it's advice to try replacing fuse. NO luck.
    Does the rechareable battery have to be replaced? Garmin appears to say that it is a sealed unit; in which case I cant get to the battery.
    Please help
  • jgwillow Jun 29, 2008
    I have the same exact problem I got my garmin 330 for x-mas. Used it for the first time in May. It would not power on. Played with it and played with it a half hour later I got it to work. Used it one more in June again it took awhile to come on. Then when ready to leave for my destination it would not power up at all, even after hitting the reset button. I tried my daughter-in-laws charger to see if that was the problem it was not. We had over 150 boxes to choose from in Wal-Mart and we had to pick up the lemon. Wal-Mart will not exchange, even though they can tell it is brand new. What can be the problem?
    Novelist:
    Champion:
  • 211 Answers
Check the power cord fuse and the input jack on the board and make sure their are no broken lead connections ( cold solder joints ) to the board. If you have a volt meter, you should be able to read 12v DC to the plug. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 06, 2008
  • Ed Meshechek
    Ed Meshechek Jan 06, 2008
    It sounds like you've done all you can to check the unit. I'm sure the processor may be dead. Time to send it back to Garmin. Sorry for that information.
    Ed
    NC Electronic
    Mills, Wyoming
6ya staff
SOURCE:
How do reset the pause button
try unplugging machine from power(or turning circuit breaker off), while power is off, push and hold on/off button for 10 seconds. release, turn power back on, and see if that resets the unit. good luck
Sep 10, 2016 | Washing Machines
I have a separate fax line for my Canon MX310. It goes into fax mode but noting happens. I also cannot receive faxes.
The only reason to call the phone company is if you're not getting a dial tone on that line. Otherwise, have you shut down the printer and tried to reset it to factory defaults. To do that, follow the instructions below:
  • 1 Switch the Canon MX310 off using the "Power" button, then push the "Stop/Reset" button on the control panel. Hold the button down for about five seconds.
  • 2 Push the "Power" button while holding "Stop/Reset." Hold down both buttons for five seconds.
  • 3 Release "Stop/Reset" while holding down the "Power" button.
  • 4 Push "Stop/Reset" twice while continuing to hold the "Power" button. Release the "Power" button. The power light will turn green.
  • 5 Once the light is steady green, push "Stop/Reset." Wait about three seconds and push it again. Wait three more seconds and push it one final time, for a total of three times. The power light will turn orange.
  • 6 Push the "Power" button, then lift the MX310 cover open.
  • 7 Remove both ink cartridges and wait 10 seconds. Replace the cartridges and close the MX310 cover. Wait 30 seconds.
  • 8 Push the "Power" button. Wait a few seconds to allow the printer to fully power down, then switch the Canon MX310 back on using the "Power" button.
  • Good Luck Mark
Feb 20, 2015 | Canon PIXMA MX310 All-In-One Printer
[email protected]
MM, most roku,s have a reset button on the back of them next to power cord, you can do a soft reset, where you take a paper clip and push in reset button for 1 second, if that does not work unplug everything except the power on roku and push in with paper clip the reset button for 15 seconds then unplug power cord, then after a couple more seconds, release the reset key, wait a couple minutes and plug everything back in and boot it up, good luck
Mar 18, 2014 | Computers & Internet
My trio stealth g2 won't turn on the battery drained last night so I put it on charge and in the morning I took it off and I pushed the power button and all it said was trio stealth g2 and it thats all...
there are several things u can try to reset it. but i have not seen many of reset and continue to work without having other problems. check out this link first.
http://youtu.be/jcreuqRxK6w
there is a reset on the back of the tablet..l use a paper clip and push the reset button and hold it until it turns off and then push the power and the sound buttons together ..sound button up. if this does
work use the power cord to charge it. if this fails return it with the link i use above..
good luck
chad man
Sep 01, 2013 | Mach Speed Trio Stealth G2 Tablet -...
How to reprogram htc evo when i don't remember my google account information?
IF YOU CANT GET IN TO THE PHONE U CAN DO A (HARD RESET)
THIS WILL RESET THE PHONE AS IF IT WAS NEW IT WILL DELETE EVERY THING ON THE PHONE TO DO THIS U NEED TO TAKE OUT THE BATTERY IN PUT IT BACK IN HOLD IN THE VOLUME BUTTON IN PUSH THE POWER BUTTON IN WHEN IT COMES ON PUSH THE POWER BUTTON THEN PUSH THE VOLUME DOWN TWO TIMES IT SHOULD MOVE DOWN TO CLEAR STORGE PUSH THE POWER BUTTON THE PHONE WILL REBOOT BACK TO LIKE NEW
GOOD LUCK
Oct 08, 2011 | HTC EVO 4G Smartphone
Seems like no power going to knob
check power at oulet blowdryer other apliance if no power reset breaker at panel to reset push breaker oppisite direction of other breakers than flip back in line with others good luck
Apr 14, 2010 | Maytag HAV2557 Top Load Washer
My canon Pixma IP1500 start blinking 10 times alternationg orange and green, then repeats. I even reset waste ink counter, but no luck. Please help me out. Thanks.
How To Reset Waste Ink Canon Pixma MP450
Hi there
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
Power off printer
Hold down STOP/RESET button then Press and Hold down Power button
Keep Power button down and Release STOP/RESET button
Release power button
Push STOP/RESET button twice
Wait 20-30 seconds - our LED showed Idle
Push STOP/RESET button four times
Push Power button twice
Power off
Next time the printer is started the waste count will have been reset.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 29, 2010 | Canon PIXMA iP1500 InkJet Photo Printer
TomTom Go720 cannot boot up/frozen screen/no response. Need repair
Try resetting it. Use a pin or straightened paper clip to push the reset button thru the hole marked "Reset" on the bottom. hold the reset for 15 seconds. then push and hold the power button for 5 seconds to complete the reset. Good luck.
Oct 27, 2009 | Tomtom GO 720 GPS Receiver
Unplug the power to move now the reset buttons are not working its on demo mode
reset buttons not making good connections...try pushing harder or wiggle the buttons back and forth while pushing down on them...sometimes they make contact that way....if you can get the unit to reset doing that then...have the button assembly cleaned out in the future...good luck
silvio
Jul 08, 2009 | Olympia InfoGlobe Caller ID
My phone is lock
reset same time push the power button in and release them both same time and hold the red button for 15 secods until u will have window saying if u want to follow the restting process...good luck
Jan 22, 2008 | Eten Glofish M700 PDA
Garmin StreetPilot C330 GPS Receiver Logo
81 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Sheldon Dedek
Janelle Schoonover
Janelle Schoonover
Are you a Garmin GPS Expert? Answer questions, earn points and help others
