When I start the TV the left side is very distorted - jumpy, blocky, fading all of these things. Eventually, it just sorts itself out and is perfect. I've just had a new antenna installed - but it made no difference! Would appreciate any advice.
Unfortunately this is an issue with the LCD panel of the TV. The only way to fix it is to replace the whole LCD panel. It is the most expensive part of the TV and usually costs around the same amount if not more than a similar brand new one. If you are still covered under warranty, call up the manufacturer to schedule a service call. If you are not, still call them to see if they will cover at least part of the cost of repair.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
Thanks for the advice and prompt reply. - I think I'm still under warranty so should be able to get the problem fixwed by the manufacturer
" - rsparvell
While watching TV, every once in a whule the sound changes and it sounds like an echo/blown out...
(More)
While watching TV, every once in a whule the sound changes and it sounds like an echo/blown out speker. If you turn tv off and on again-it is fine. 46" hdtv , comcast dvr box. went through 3 boxes and exhanged tv- same problem.
