Question about Toshiba Satellite A135 Notebook
Hard Drive Never Stops Running Even when not engaged.
Toshiba Satellite 135 laptop. My disk is always running & audible. Seems to have started after downloading MS Service Pack 3. Using Vista OS. This is driving me nuts. Is it a PC problem or a software issue? Please advise as still under Manf warranty and need to know if it should go back or how to fix it. Thanks.
  • Tega Jan 06, 2008
    Tom- Thanks for the quick response. I did turn off the indexing as it was on, however, the drive is still running constantly. I have the google Vista toolbar on my pc. Could that be causing it?
    Hard drive seems to speed up quickly, slow down and create noise. Disk drive icon button flashes constantly when this running occurs. Not running anything other than Explorer at this time.
    Genius:
  • 1,601 Answers
Windows has a indexing service that runs constantly. It is supposed to speed up searches on your computer. I always turn mine off. to turn yours off: right click on the "C" drive, properties, uncheck indexing. Also things running in the background, I disable that I dont need.
Posted on Jan 06, 2008
  • Thomas Christopher
    Thomas Christopher Jan 06, 2008
    Google toolbar can do it.
    Go to Run, type msconfig, and shut down things that you dont need. then restart.
6ya staff
SOURCE:
When I star up my computer Toshiba a135-S4427, it boots up and then goes to a blank black screen. I am unable to get to the log in screen. It just sits there, I can hear the processors and the fans...
Seems a problem with RAM. Remove your RAM from the slot and start the PC, long beep sounds are audible, then the RAM is OK, else time to buy a new RAM/ memory.
Else Try for the Hard Disk, Check the Hard disk in your's friend's PC, remove his Hard disk and insert yours, if the same problem arises, change the Hard Disk or if nothing happens, system boots,
it seems a problem with motherboard, Get it repaired by a expert or buy a new one.this will work.
Enjoy !!! Thank you for using Fixya !!!
Nov 14, 2010 | Toshiba Satellite A135-S4427 Notebook
How do I remove the hard drive in Toshiba SatellitePro A10 EN? (Removing the plastic cover exposes only the end of the hard drive. I'm reluctant to just start pulling on it!
  • The original Toshiba Satellite Pro A10 HDD is fitted into a Toshiba Satellite Pro A10 Hard Disk Drive cradle - Toshiba Satellite Pro A10 HDD caddy.
      • Gently remove the cradle from the laptop, yes pull on it
      • Unscrew the original Toshiba Satellite Pro A10 Hard Disk Drive & remove it from the cradle.
      • Screw the new Toshiba Satellite Pro A10 Hard Disk Drive into the cradle & refit the cradle into the laptop.
      • Re-install XP or Vista
          Aug 21, 2010 | Toshiba Satellite A10 Notebook
          How to reformat my laptop,toshiba satellite u 300.thansk
          with what operating system?
          There are two ways...
          (1) take the hard drive out and connect it to another computer, right click on the drive, and click format
          (2) You need a windows or other operating system disk....just start it like you were going to install windows, and select advanced disk options (it's a link, easy to overlook but it's always there)
          You can not format a disk with a running operating system on it.
          There are other "bootable" disks you can also format the hard drive with...an Acronis Backup boot disk, probably a Norton Ghost boot disk....things like that...not all bootable CDs, but usually a backup or disk imaging program will allow you to format a hard drive
          Jun 15, 2010 | Toshiba Satellite U300-ST3091 Notebook
          Runs very slow... hard disk constantly running
          You need to defrag your drive, make sure no unnecessary resources are running in the background and delete your temp folder as this fills with allsorts of rubbish you do not need and slows the operating system significantly.
          Jan 05, 2010 | Toshiba Satellite A45-S150 Notebook
          My Toshiba Satellite A105 keeps hanging up. It
          No matter what, backup your data now.
          Then try running a hard disk scan to check for bad sectors. Some software apps will actually block off the bad sectors and prevent your system from trying to use them again.
          However, I suspect that the issue is actually a memory or video card problem. Try installing memtest86 (http://www.memtest86.com/download.html) and running on your system.
          -Jon
          Sep 29, 2009 | Toshiba Satellite A100-S8111TD Notebook
          System Restore
          It seems that your computer is not booting from DVD-ROM drive nor hard disk, but is trying to establish a network setup of the operating system.
          You have to go to BIOS settings and correct these preferences by making your hard disk the first boot device. Of course that would be a solution if you have operating system installed on it. If there is no operating system installed on the hard disk, you will need to install it. In this case, your first boo device would DVD-ROM or CD-ROM, whichever available.
          Jan 16, 2009 | Toshiba Satellite M35X-S349 Notebook
          My laptop Toshiba Satellite A205-S4577 does not re-boot
          start the machine and immediately press the setup button to get bios setup options. In this you have to set the cd/dvd as the first booting device. that's all. good luck.
          Dec 18, 2008 | Toshiba Satellite A205-S4617 Notebook
          No Display, no audio, no power up sounds.
          Sounds like a hardware failure because your not even reaching post. which means that its not software. i would take out the ram and hard drive. and then putting them back in. if that didn't do anything than I'm going to say you've probably got a dead mother board.
          Aug 19, 2008 | Toshiba Satellite A135-S2276 Notebook
          Toshiba Satellite pro hl-dt-st dvdram gma-4082n
          goto program defaults/media player/disc insertion= and choose the options you require. Or goto computer-cd/dvd drive and choose the program you wish to run the disc
          Dec 10, 2007 | Toshiba Satellite A135 Notebook
          Toshiba Satellite A135 Notebook Logo
          334 people viewed this question
          Top Toshiba Computers & Internet Experts
          Ekse
          Alun Cox
          k24674
          Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
