Question about Arris SURFboard SBG900 (49402201900) Modem
Can not connect web cam and view outside of home network
I'm trying to set up a webcam. I have a SBG900. Have turned off the firewall completely, have verified my ISP does not block any incoming ports, and I am still unable to connect to the SBG900 from outside my home network (eg. I've tried to connect to the IP address I currently have assigned to my router by Comcast from an external computer via the web, and can not connect. As I'm unable to even see the router, of course can't see the webcam either).
I've already set up port forwarding to the webcam local IP address, and it's not working, so this isn't the problem. Any other advice you can offer on how to fix?
Thanks in advanace
  • MikeyHD May 11, 2010
    Ihave the same problem. I am trying to set up a Panasonic internet camera. It uses port 80 so I have set up port forwarding from the gateway/router to do ths. The router is an SBG900. I have turned off the firewall and assigned the address as 192.168.0.1 as the gateway with the camera being 192.168.0.253 and the port to be forwarded as 80. Nothing seems to get past my router. I see your note for modem config data. Where would one obtain this info?
    Problem Solver:
  • 7 Answers
Try to see your modem config and send the data.
regards
Posted on Jan 06, 2008
How do I torn off fire wall on my time warner cable ARRIS wifi router
See step 2; it's a matter of just clicking the firewall protection to OFF, from the "set up firewall protection" menu.
Set Up Firewall Protection
You can set up firewall filters and firewall alert notifications on your wireless home network. You
can also block Java Applets, Cookies, ActiveX controls, popup windows, Proxies, and website
access. See Protection Level for more information.
To set the firewall protection level:
1. From any screen, click the Firewall-Protection Level menu link or click the Firewall menu
button on the SBG6782-AC Main Menu and then select Protection Level.
Figure 17 - Firewall Protection Level Screen
2. Click the Firewall Protection Setting drop-down button to select the firewall protection level.
Possible values: Low, Medium, High, or Off
Note: Selecting Off will disable firewall protection on your home network. Your computer(s)
and other Ethernet-enabled devices on your network will be at risk for possible attacks from
viruses and hackers.
3. Select each Web filter that you want to set for the firewall and then click Apply.
Feb 24, 2015 | Arris SURFboard SBG900 Wireless Router...
A network error occured while conecting to the server. i get this error evry time when i whant to invite someone to view my web cam. what is rong ?
Probably your firewall or network settings. Check that the program you are using is defined as an exception in the firewall, and see if any ports need to opened.
Here are more details: http://www.pcauthorities.com/pc-errors/how-to-fix-webcam-problems
Oct 21, 2010 | Labtec 961307-0914 Webcam
Motorola Surfboard SBG900 will not connect to Playstation Network
You need to give the PS3 its own IPAddress outside of the firewall. You need to configure the router and the PS3.
Mar 13, 2010 | Arris SURFboard SBG900 (49402201900) Modem
I'm trying to set up my panasonic webcam wirelessly and I'm able to see the camera from my in network but unable to view it from work. Under my 2wire home network router i don't see the webcam as one of...
Dear Sir,
First try to check the ip of your webcam that you have connect by it.
second check the firewall on your router if it use any port and the firewall blocked it.
Sep 11, 2009 | Computers & Internet
Web cam not working
Hello have you check the cam with another system or check the connection well and make sure the cam is on then reconnect it to the power source and make sure you click on the view webcam to view others persons webcam
ok
Rate this solution
Oct 16, 2008 | Computers & Internet
Hp web cam
Normally, If you are running Windows XP, the Built-In Internet Connection Firewall (ICF) maybe enable without your knowledge. This is the default setting of Windows to protect your PC from hacking. However, of course, this default setting may block you from running some applications you might need to use like Viewing WebCam in Yahoo! Messenger. Anyway, there is always a way to solve the problem.
Below are the steps to enable you to veiw WebCam by instructing you to ensure that the correct ports are opened.
1. Click Start, Settings, and select Control Panel.
2. Double click on the Network Connections icon.
3. Right click the connection that you use to connect to the Internet, and then click on Properties.
4. On the Advanced tab, uncheck the box Protect my computer… if you would like to disable the firewall. If you like to only open the webcam ports, check the box and continue with the remaining steps.
5. Click the Settings button.
6. Click the Add button.
7. Under Description… fill in Yahoo! Webcam. Under Name or IP… fill in 127.0.0.1. Under both External Port and Internal Port fill in 5100. Check the button TCP.
8. Click OK to close all opened dialog boxes.
Work done! I guess now You can view webcam in Yahoo! Messenger
That will resolve the issue.
However, if the issue persists, you can try below thing. By disabeling and enabling the webcam feature.
Disabling Webcam application:
Disabling Windows Image Acquisition (WIA) service will disable the webcam.
1. Click Start, and select Run.
2. In the Open box, type SERVICES.MSC
3. Press Enter on the keyboard. Services box will pop up.
4. In the Services window, scroll down to Windows Image Acquisition (WIA) service. 5. Right-click "Windows Image Acquisition (WIA)" and select Properties.
6. In the General tab, under Service status, click the "Stop" button.
7. Click Apply and OK.
8. Restart the notebook. This will disable the webcam on the notebook
Enabling the web cam application :
6. In the General tab, under Service status, click the "Start" button.
8. Restart the notebook. This will enable the webcam on the notebook.
Sep 07, 2008 | HP Pavilion dv6000z Notebook
Doesn't work on my home network on MSN/WLM
this could be a problem with WLM's permissions with the firewall. First check to make sure the webcam is working by using the software that came with it. And make sure if it is a quickcam that the software it came with is active. If your home PC isn't recognizing the cam it could be not plugged into a USB 2.0 port, or the driver is corrupt etc etc. If it is recognizing it then check that WLM has proper permissions in your firewall for sharing the image. Also allow WLM to calibrate the webcam, which is available under it's tools.
Further if the latest version doesn't want to work with your webcam there could just be a simple incompatability. I'd try to rollback the wlm back to an earlier version.
Jul 27, 2008 | Logitech QuickCam Messenger Web Camera
VeoNetwork Web cam
You can view your Veo Observer web cam at home by either of two methods. The first is to use the Observer Studio software that came with the camera. When you configured the camera, you selected a local (private) IP address for each Veo Observer, and set the address specific to each camera. You then put the same IP address into your Observer Studio Software.
Depending on the brand of router you use on your home network, your Veo Observer camera probably has a local (private) IP address in the format 192.168.0.xxx or 192.168.1.xxx where "xxx" is the actual address assigned to your Veo Observer (by you) and configured to display on the LCD window on the side of the Veo Observer.
You may need to log into your router to see which of the two local (private) IP address formats is used. Your router's user manual will show you how.
To view your Veo Observer, just type the exact local (private) IP address in your IE browser. for example, if you assigned address 100 to your cam, you would enter http://192.168.0.100 or 192.168.1.100 into your browser. Veo Observer will display the Language selection screen. Choose the language, then you log in and view your camera.
To view your camera from outside your home using another computer, you use the same method, but you have to substitute your WAN (public) IP address.
You can log into your router and select its STATUS tab to view your WAN (public) IP address. See you router's set up guide if you do not know how to do this.
An easier way to determine your WAN (public) IP address is to visit Gibson Research Shields Up! web page:
https://www.grc.com/x/ne.dll?bh0bkyd2
and scroll down to the last paragraph where you will find your WAN (public) IP address.
For example, if this address is 123.456.789.100, then you would enter http://123.456.789.100 on your IE browser. You should see the Language select screen, choose your language, then log in and you are now viewing your Veo Observer from outside your home.
Note: when you view your Veo Observer at home, you probably have a fast frame rate and smooth video motion. When you view your Veo Observer from outside the home, the frame rate is certain to be less, and your moving image quality will be choppy. This is normal, as viewing from outside the home is less efficient and the image suffers. There is nothing you can do to boost the frame rate.
Jun 15, 2008 | Veo Observer Network Camera
Mycam
You hav answer in front of you.different firewall settings
Dec 31, 2007 | Creative Labs WebCam Live! Pro
Arris SURFboard SBG900 (49402201900) Modem Logo
431 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
