i have LG Studio works 700E CRT monitor i bought it on year 2003. i could find color problem in it...
(More)
i have LG Studio works 700E CRT monitor i bought it on year 2003. i could find color problem in it red color is showing dark black..how to solve it..all my cards are working properly...i have checked by placing a graphysic card but no use...problem is not rectified..can u help me..
I?m using a Philips 104E 14? monitor. When I use it, it goes off suddenly (no even standby LED) and...
(More)
I?m using a Philips 104E 14? monitor. When I use it, it goes off suddenly (no even standby LED) and then it couldn?t be turn on. When it?s working I can?t control the horizontal width even with the control battens. I did following troubleshooting steps : 1. All dry-joints were soldered. 2.horizontal transistor TIP122 and H-Out transistor were replaced with new ones but problem still remain same. 3 .then in order to check the voltage at H-out transistor, 230V bulb was connected to the points where E and C of the H-out transistor were connected. (and H-out was removed from the board )When I turn on the monitor I found the bulb is blinking (this is abnormal and fixed voltage should come to the h-out Tr, I think.) ******After removing the H-out transistor amber color LED came up. Can this be a Fly-back issue? Please guide how to troubleshoot this Kushan
The "Main Menu" screen keeps popping up in the middle of the monitor. Will not stay off...
(More)
The "Main Menu" screen keeps popping up in the middle of the monitor. Will not stay off when "exit" is pushed.
