Guest
Rank: Apprentice
Rating: 0%, 0 votes
Sounds as though your tuner module is not working or you have a lack of signal to the tuner. You need to be sure that the set hasn't been switched to a different mode ( ie: from tuner to video..etc ). If all is correct in that matter, are you using a satellite dish. If you are infact using a satellite dish, then the signal strength from the satellite is not suffecient. ( you may need to realign the dish ). If you are on a cable signal ( cable TV ) you may have a bad input cable and need to call the cable company to check their input line. If all is well with the signals coming in, then infact, you may a bad tuner module in the TV. Good Luck
Ed NC Electronic
Mills, Wyoming
