Question about Polaroid FLM-2601 Television
Power problem... i have a Polaroid flm-2601 and the power won't come on a red light come on buts that about it and when u push the power button on the remote or television   it turn off completely.can you help me ?
  • 7 more comments
  • sailors Mar 29, 2008
    Our Polariod tv when the tv is off the red is when you turn the tv on the blue light comes on but the screen is black.
  • Anonymous Apr 20, 2008
    I have exactly the same problem and my TV is only a little over a year old.
  • Anonymous May 19, 2008
    Power won't come on
  • seaflow Jul 24, 2008
    Will not come on... For while I could unplug AC and then would come on after repluged...
    Steve
  • Anonymous Feb 23, 2009
    My caps that read 1000uf 35v are not bulging. Could they still be at fault?
  • Anonymous Apr 20, 2009
    does anyone have any pictures or better info on replacing these. Mine does a similar thing. The red light will come on then when you hit the power button it shuts off and comes back on again a little later. If i leave it unplugged for about a day or so it will sometimes come back and work once or twice?
    I want to fi it myself and just need to know what i am looking for!?
  • rusty87jeep May 15, 2009
    red light is on all the time. When you press it it will go off then come back in a few seconds.
    If you unplug the tv for a few minutes then plug it back in... when you plug it back in it pops a tiny bit then when you hit the power button it pops again and the blue light will flash then the whole thing goes off.
    This sound is coming from the power source. i took it apart and tried it. The power source visually looks fine!?
    Do i need to replace it or what? and Where do i find the replacement?
  • Anonymous May 11, 2010
    Ok so I didnt replace the caps yet but I am using the tv as my monitor. The problem mine had was once you had taken out the board from the tray, there was a samll cylinder type cap that blowout the solder. Well for trying to eliminate a problem, I just went ahead an resoldered that joint, put the ps back into the tv, and BAM!! the polariod logo cam on, I was like NAWICE!!! so now i am using it. All it took was gettin gthose caps here for me to take the board out the case. but in reality it costed me nothing had I not purchased the caps. Which, still I am glad I did because i am sure they will go eventually.
    The sypmtoms I was having was the red lights would come on but no picture. they would turn blue either
    ok I have gotte nthe caps that read 63v at 1000uf and they seem to be bigger. also, when I took the board off the plate, there is a burn spot from something else that blew on it. The little guy dosent have a number on it but it is a cylinder looking cap. I took the glew off of the solder was not even making contact. how do i know if this is the problem? I havent replaced the caps because they are not bulging. I ordered them because that is what I have read a lot that it is those that are the problem.
    Problem Solver:
  • 7 Answers
I just repaired mine by replacing the 2 electrolitic caps on the power supply that had a bulge on the top. they were 1000uf at 35 volts---works again!!!!
Posted on Feb 20, 2008
What can be don to up grade the part if it happen to all the hd it seems thou they all over heat
Posted on Mar 01, 2008
  • 579 Answers
These Poloroid TV's all fail like this. Take it back if you can. If not, call the warranty and have them replace the module. Or, If so inclined, you can upgrade the capacitors in the power supply.
Sorry for the bad news.
Hope Ya Fix it!
Posted on Jan 06, 2008
I have found similar problems in the power supply of the main boards. I normally try to order the main board if the manufacture has it avaidible. The cost starts at about 100 dollars normally. Good Luck
Ed
NC Electronic
Mills, Wyoming
6ya staff
SOURCE:
No power just dead, even when using the remote and the t.v. power button
ya bad transformers in these models sad to say cost around 200 local tech shop take it in these are the cheaper line know for having bad power
Feb 04, 2008 | Polaroid FLM-2601 Television
Polaroid FLM 2601 flat panel TV won't turn on
Power supply board is dead.Replaced the power supply board.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 18, 2010 | Polaroid FLM-2601 Television
My 26" lcd television FLM-2601 polaroid is not working it constantly stays in standby mode you push power button and blue light flicks on then goes right back into standby mode how do i fix this?
First of all, check your input source on your TV.
Turn on TV.
Press the Input button on your remote.
Make sure the Source Input matches the corresponding device that is wired on the back of the TV.
Nov 12, 2009 | Polaroid FLM-2601 Television
Polaroid flat panel tv will not turn on. the red
you have a blown cap in the power supply it will be puffy on top replace them or have it done
Sep 19, 2009 | Polaroid FLM-2601 Television
How to access the inside of flm-2601
First- unplug it, Second- remove the back( can be tricky), Third- follow the AC cord to the power supply board and your there. Look for any Caps that may be bulged and replace them. Sometimes caps can be bad and look ok. Let ame know how you do>
Mar 20, 2009 | Polaroid FLM-2601 Television
Doesn't turn on
Pretty good chance the power supply board is bad. A number of capacitors will become leaky and you lose all power. Some techs still know how to do component Laval service but most just change the board $$$$
Jul 10, 2008 | Polaroid FLM-2601 Television
Need to buy a new remote
Try Vance Baldwin a parts dist in florida
the handle Polaroid tv's
Oct 21, 2007 | Polaroid FLM-2601 Television
Tv won't come on
chech ur line trasiformer frist of all check the collector voitage if it is ok
Jan 20, 2007 | Polaroid FLM-2601 Television
Polaroid FLM-2601 Television Logo
492 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
