Question about Dryers
Squeak The dryer makes an awful squeaking sound while running. My 7 year old Kenmore dryer (Model # 417-69042991) has started doing the same thing. It will squeal terribly for 3 or 4 minutes at first, then settle down some. Once it gets close to the end of the cycle, it will start squealing loudly again. My husband took the entire thing apart and could find no sign of anything wrong (broken belt, etc.). It's driving me crazy!
  • Anonymous May 24, 2009
    What type of grease is used?
    President:
  • 878 Answers
Pinot, usually the squeak on these 417's is coming from the drum ball and plastic bearing. Sometimes they crack and sometimes just need to be greased. Go to this link http://www3.sears.com/ and enter your model number, upper left hand corner. Follow the link and click on view diagram, page 1. Look at number 12 and 34. This is the drum hitch and plastic bearing. Your husband will have to remove the top and once he has the belt off, pull up on the drum to get it off the bearing, (plastic coupling that the ball sets into. If it's not cracked and the ball is is good shape, just grease it. If it's cracked and the ball is a chewed up, replace them both. This job is done better with 2 people cause it's not the easiest deal. You can find the part numbers on the parts link right next to view diagram. Let the cat know if you need any more help, Catriver.
Posted on Jan 06, 2008
My whirlpool (ggw9250pw3) gas dryer loud squeak
THIS SOUNDS LIKE AN IDLER PULLEY THAT KEEPS THE TENSION ON THE BELT. SECOND CHOICE WOULD BE DRUM ROLLERS.
Apr 24, 2010 | Whirlpool GGW9250PL Gas Dryer
Dryer makes loud squeaking sound when spining
how old? Dryers squeak for one of 3 reasons..bad belt, bad motor or drum rubbing against dryer framework.
run it empty...intermittent squeaks usually are the drum...something's bent
continuous- is there any burning smell? If so, most likely the motor, if not, possibly the belt.
Open the top (most have screws or can just be pried open) and watch it run...identify the source of the sound if possible
try spraying the belt and motor with a little wd-40 and let it dry for a day, then try again.
If that doesn't help, repairman or new/used dryer...probably better off to find a decent one off of craigslist b4 paying to repair an already faulty machine
Feb 22, 2010 | Kenmore 62802 Electric Dryer
Kenmore 417.80042990 (10 year old) dryer makes a squeak as it tumbles the clothes dry. Seems to be worse as the clothes get dryer. FYI-the felt was replaced about 4 years ago, not sure it's that. But...
this is a frigidaire made dryer with kenmores name on it. The drum bearing needs more grease. You really need to know what your doing before you take that job on yourself. Its easy for me...but I have been doing it for 20 years and thats the way I role
Nov 11, 2009 | Kenmore 98702 Stacked Washer/Dryer
Maytag Dryer, 25 year old dryer has a loud squeak
Hello.
The squeaking is coming from the rollers that the drum rides on. If you take the model number to a local appliance service store they will have the parts and be able to direct you on replacing them.
Jul 20, 2009 | Maytag PYE2300AY Electric Dryer
Squeaky Kenmore Dryer
The idler rollera and belt tensioner have got bearings. One of them is failing.
Jul 07, 2009 | Dryers
Need to know how to remove the motor on a Series 80 elec dryer.
The motor should be removable from the back and will require removal of the back panel. The bearings on these motors are brass "bushing" type, not ball bearing. You may have some success oiling them with a straight weight oil like 30w, but it may not last too long. Once the bushings start to go, it's usually time to replace the motor. You should be able to get another motor for the unit from Sears Parts Direct. I applaud your efforts!
Mar 28, 2009 | Kenmore Dryers
Squeak
It is proably the center bearing in the back of the drum, especially if it at least a few years old. It can be replaced by you if you are very handy.
Dec 22, 2007 | GE DBL333EA Electric Dryer
Dryers Logo
932 people viewed this question
Top Dryers Experts
